Question about Vacuums
With a/c on max, and either excellarating or accending I seem to lose vacuum and vent goes to defrost , then when slowing down it goes back to normal settings. , check valve new, vacuum ball no leaks ????? blazer s10 1997 4wd
    President:
  • 1,673 Answers
You need to repost this in the auto. repair section, this is for vacuum cleaner repairs.
Posted on Jul 13, 2008
My dyson DC 59 Motorhead works fine for a period of time then just quits. The run time seems unusually short and does not slowly lose power but stops abruptly. What is the problem?
Modern lithium Ion rechargeable batteries don't slow down as they discharge, they run full appliance and then just boom they are dead. You need a new battery
Nov 30, 2016 | Dyson DC59 Motorhead Bagless Cordless...
My Panasonic vacuum sounds weird I cover a little blower vent and it goes back to normal sounding Just changed bag filter doesn't look real dirty, never changed
if the noise goes down when you cover the hole, the problem is that the vacuum hose or that side of the machine is blocked
that is less load for the motor and so it goes faster
blocking the hole prevents air out and so the motor slows down
the same effect as if you put you hand over the hose , the motor speeds up
Nov 26, 2015 | Panasonic Vacuums
Hi! My Dyson DC17 starts fine and then, within a second, gets very loud with an extra sucking noise.
Hi there, it's Jack at Dyson.
Like most Dyson vacuums, DC17 includes a suction relief valve. This allows extra airflow into the vacuum to protect the motor if the machine is used when blocked. If you've already washed the pre-motor filter and checked all the ducts for blockages, it's possible there's an issue with your machine's cyclone pack which has caused it to block.
We'd appreciate the opportunity to help you check for this - please do not continue to use your machine in the meantime as this may cause damage. When you have your DC17 easily to hand, please give the Dyson Customer Helpline a call on 1-866-693-9766 (US), or 1-877-397-6622 (CA).
We'll look forward to speaking with you.
Mar 14, 2015 | Dyson Vacuums
How do I change from MAX to normal on my Dyson59 vacuum cleaner.
Hi Betty, it's Jack at Dyson.
To change your DC59's power level from Max to normal, just hold down the on/off trigger so the vacuum is running, then at the same time press and release the Boost button on the rear of the machine. When Max mode is activated, the Boost button will light up - when normal mode is activated, the Button will not light up.
I hope this helps, but if you'd like further information or advice please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dec 03, 2014 | Vacuums
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Eureka 9410 upright vacuum motor
They normally have a reverse thread nut on top then just pushed down on a tapered end so needs to be levered off normally a wide flat blade paint scraper etc can help spead load so fan doesnt break or distort
Apr 13, 2017 | Vacuums
I have a Eurkeka Boss vacuum and having problems with suction with the hose attachment. Have checked the normal things. ???? Any suggestions?
Since you've checked all the normal things, I presume you mean making sure the hose is unblocked. Now, have you checked the hose for the suction vent/adjustor? There is usually a vent with a movable cover that moves away from the vent and back over the vent. If the vent is open, the suction decreases. If the vent is covered, the suction improves. Many times I accidentally move the cover so that the vent is open and then I wonder what is wrong with the vacuum!
Hope this helps. If it does, please rate my suggestion! Thanks.
Jun 02, 2011 | Vacuums
Belt broke how do i chane this
Lay it down on its side, unscrew the cover over the brushes (don't lose them). You may have to pull the brushes out depending where the belt goes. Slip the belt on where it goes and put everything back together. The roller may be a little hard to put back in because of the new belt being tight but it will go on with a litte pushing. Good luck. Mine breaks all the time so I have it down to an art on mine. Just takes a few minutes.
Feb 19, 2011 | Dirt Devil 12 Amp HEPA Filter Vacuum...
I have a Sebo x1. It will not pick up from the head.
Hi
If the wheel isn't moving when the upright handle is swung down normally then the hydrallic action will be broken. The wheel only adjusts to the carpet when the handle is swung down and the wheel goes to the highest position. HOWEVER if you have large pile / thick carpeting then the X1 will struggle to pick this up as it doesn't cope well with thick carpeting. Sebo's G1 series with a manual adjuster dial is better in that respect. Put back the wheel as normal and check that it is lowering once the handle is unlocked. If it doesn't show up with the lights on the front of the hood showing that the wheel is going down, then its either the carpet thickness or the hydrallic wheel mechanism is broken. Contact Sebo in your country and they can usually send out a line diagram or suggest a repair.
Jan 30, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Vacuums Logo
61 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
