Question about SaniServ 401 20 Quart Ice Cream Maker
Saniserve 707a margarita machine
Our Saniserve 707 has stopped freezing the mix.High side pressure reads 150lbs with compressor on.Spec's call for 300 lbs.Does it just need more 404a?
Dan
  • 30 Answers
The best thing to do would be to recover the 404a into a clean recovery jug,weighing how much you take out. Check the nameplate on back it will tell total ref charge. in either oz or lbs. then weigh the charge back into the unit. this is the best wayto verify if you have a proper charge.If the unit is low on charge then you will want to find and repair the leak as soon as possible.
Posted on Mar 07, 2009
Compressor hpco code comes up on panel of Taylor soft serve ice cream machine? Does that mean lack of water to machine?
There is a very good chance. Often the water has been shut off, or a wheel is pinching the hose.
HPCO stands for High Pressure Cut Out. The high side pressure is regulated by the water valve on water cooled equipment.
These are links to parts in the water cooling system.
046686 Water Regulating Valve 3 8
048287 Condenser for Taylor Water Cooled machines Taylor 035174 Scraper BladeReplacement 17
May 28, 2017 | Taylor Ice Cream Makers
Compressor hpco
Compressor hpco or (High Pressure Cut Out) means the high side pressure has went over the limit the machine has been set too. The safety is there to protect the compressor. If the machine is water cooled, the water flow has most likely been interrupted. So often the machine was moved for cleaning and the wheel is on the water hose. If the machine is air cooled, Either 1. the fan has stopped, 2. the condensers are dirty or 3. It's just too hot where you are trying to run the machine.
Soft Serve Parts C723
May 06, 2017 | Taylor Ice Cream Makers
Taylor 8756-33. Which components operate in standby mode?
In standby mode, the machine just wants to keep the product refrigerated until it goes back into auto.
So, the mix cabinet needs to keep the product cool in the bottom of the machine, that requires the mix compressor and fans to run. The mix cabinet temperature is read by a thermistor probe and regulated by the (left side) logic board.
The product in the cylinders should go back to liquid form in standby, but we still have to maintain that safe food temperature, the motor and compressor will run periodically. If the machine is air-cooled a fan will run anytime the compressors run. If it is water cooled, water will flow through the machine when the compressor runs. The temperature in the freezing cylinders is read by a different thermistor probe and regulated by the logic boards.
Here is a link to all of the parts in a Taylor 8756.
http://www.softserveparts.com/c-1335911-parts-8756.html
Jul 20, 2015 | Taylor Ice Cream Makers
Hello I have a 8754 Taylor and having trouble with the (chocolate)left side of the machine.The product goes soft after I've served about fifty cones. this is what I've tried *installed all new o rings...
sounds like a freon like to me if the compressor is running for long periods and not freezing properly or you have a water pressure issue. if it is water cooled which alot are it is hard to realize you have a freon leak.
Dec 12, 2014 | Taylor Ice Cream Makers
Soft serve machine freezing solid
POSSIBLE CAUSES• Mix hopper is empty, freezing cylinder starved for mix.• Mix in hopper contains ice particles, mix feed tube clogged.• Machine turned too cold
ACTION REQUIRED• Add mix to hopper. Put machine in wash mode to help thaw freezing cylinder.• Pull mix feed tube to fill freezing cylinder. Replace mix feed tube and put machine in wash mode to help thaw mix in freezing cylinder.• Follow manufacturer's recommendation for the proper temperature for the mix being used.
Apr 12, 2013 | Ice Cream Makers
I hooked up my gauge run the unit and sees the high side pressure goes up, the compressor overheating and shuts off. I checked the water pressure regulator valve it good. so I unwelded the condensor coil...
It sounds like you may have unwelded the suction line to the compressor and blew the compressor out. That is not good. How a Taylor works is this: Compressor comes on and produces a lot of heat. There are 3 ways to dissipate the heat. If there is a big radiator like set of copper and aluminum finned coils near the compressor it is air cooled. If there is a water line going in and a drain line coming out, it is water cooled, the water runs the whole time the compressors are running, the third way is to have an outside remote condenser coil. I believe you have a water cooled machine. On the back of the machine is a copper fitting to hook up the incoming water lline. There is also a drain line and water will flow constantly from it if everything is running alright. It is ok for the compressor to get hot when running, it is supposed to get hot. If you broke into the freon lines by mistake, the freon is gone and it won't show pressure anymore. I don't see any way that oil would have gotten into the water cooling line. To verify which is the cooling water, the copper lines will go into the back of the machine and will be wrapped around the outside of the compressor and then back to the drain at the back of the machine. If you blew the oil out of the compressor it will very soon lock up and be destroyed. Look at the line that you cut into.
Oct 20, 2010 | Taylor 632-27 Ice Cream Maker
Ice cream machine was making ice cream and now the machine runs but will not freeze the mix it is like a milk shake
a.improper pressure switch setting . b. low refrigerant level. c. TQC needs adjusting. d. faulty solenoid. e.insufficient mix in freezing cylinder.
Sep 06, 2010 | Taylor 632-27 Ice Cream Maker
I have a saniserv 707a and the product won't freeze. The refrig line is freezing right after compressor switch.
my saniserve ice cream machine will not get freeze hard or freeze when u press the button on for the compressor to kick , it will not kick in.
May 12, 2010 | SaniServ 401 20 Quart Ice Cream Maker
What brand compressor do saniserv use
Depends on the unit, goto to www.saniserve.com ,they can tell you the exact compressor by the model and serial numbers.
Feb 26, 2008 | SaniServ 401 20 Quart Ice Cream Maker
SaniServ 401 20 Quart Ice Cream Maker Logo
503 people viewed this question
Top SaniServ Ice Cream Makers Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Are you a SaniServ Ice Cream Maker Expert? Answer questions, earn points and help others
