Brother-2240c on the screen shows can't clean it and there was a peep sound coming out of it. I need to know the problem cause it is a new fax machine.
No, but there was sound of a motor running and print head didn't move at all.
Posted on Jul 14, 2008
When I send a fax from my Brother 845CW Printer, the fax, when received at the other end, has several dark vertical lines on the fax making the fax unusable Thanks for your help
This is not necessarily your fax machine causing this problem.
Sounds link the fax on the other side has the problem, however if you can look at your scanning surface and see if it needs to be cleaned. If it does use a damp cloth to clean the surface.
Do not use windex or similar product to clean.
Hope this helps.
Please rate if this solution helps.
Regards,
Apr 19, 2011 | Brother MFC-845CW InkJet Printer
How to repair a brother . show on screen clear Unable 46
unable to clean 46 is showing because of its waste ink absorber count is full. u have to go to sevicemode and can reset it on funcyion 80
Jun 12, 2010 | Brother IntelliFax Fax/ Phone/ Copier
How do I clean the drum of a brother fax machine?
Move the blue slider on top of the cartridge side to side 10 times.
Mar 03, 2009 | Brother IntelliFax-2820 Laser Fax
Lines on the paper after copying and receiving fax
look on top of the toner cartridge for a blue slider.
do it 10 times.
Jan 29, 2009 | Brother IntelliFAX 2800 Laser Fax
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
I have brother intellifax
The set up procedure is menu driven. Just press the function button and the menu will scroll on the screen. There is a "tree" of menu items, can't go through them all. But on some Brother machines there is a "Help" button which will print out a whole menu for you. If not on your machine, just be patient and list down what each menu will give you. I believe Function 1 is the fax setup. Just follow the instructions on the screen.
Jun 13, 2008 | Brother Office Equipment & Supplies
BROTHER "MFC-3820-CN" TROUBLESHOOTING
You need a new print head.
You could try cleaning the one on there, but all brothers similar to yours are plagued by this problem.
To clean it try:
SWITCH MACHINE ON WHILST HOLDING DOWN MENU/SET KEY, THIS PUTS MACHINE INTO FACTORY SETTINGS MODE.
(MAINTENANCE WILL SHOW ON LCD)
ENTER CODE:84 & WAIT WHILE MACHINE PERFORMS A FORCED CLEANING CYCLE.
(cLEANING WILL SHOW ON DISPLAY)
NOW ENTER CODE:09 & MACHINE WILL PRINT OUT ITS PRINT QUALITY CHECK SHEET.
(IGNORE INSTRUCTIONS PRINTED ON CHECK SHEET)
CHECK QUALITY & REPEAT BY USING CODE:84 IF NEEDED.
(YOU MAY HAVE TO DO THIS SEVERAL TIMES BUT YOU SHOULD SEE A STEADY IMPROVEMENT WITH EACH CLEANING CYCLE)
WHEN FINISHED AND QUALITY IS GOOD, ENTER CODE:99 TO RETURN TO STANDARD MODE.
PRESS MENU/SET 4, THEN MONO FAX START TO PRINT OUT
PRINT QUALITY CHECK SHEET & FOLLOW ON SCREEN INSTRUCTIONS.
Feb 11, 2008 | Office Equipment & Supplies
Black lines on out-going faxes/Brother MFC 1950
Have you cleaned the glass?  That's usually what causes that problem.  Lift up the lid so you can see the glass slit that your original slides against as it scans.  Make sure it's clean.
If the problem continues, you might need a new scan lamp.
Oct 29, 2007 | Office Equipment & Supplies
jasbo
jasbo
