Question about LG Refrigerators
Have an LG refrigerator model LRFC22750TT. Evaporator motor suddenly making a grinding sound. Afraid it may stop turning. Will the faceplate come off from within the box so I can view the blades?
I saw a lot of ice buildup on the back wall by the evaporator fan. I unplugged the unit took the food out and used a hair dryer to defrost the ice. Works fine now. Thanks.
Posted on Jul 18, 2008
My Coleman evcon starts out good and then all the sudden it seems to freeze up the lines and stops working. Can anyone tell me why or what i should do? Limited income for repairs and summer is kicki
Hello, sounds like either low airflow or a low refrigerant charge. The air slows down because the evaporator coil on the inside turns into basically a block of ice and blocks airflow. I would first make sure air filter is clean, evaporator coil is clean and that the blower motor is clean and running at proper speed. If that checks out good then the unit has a low charge.
Jun 02, 2012 | Whirlwind FH-778 Air Conditioner
I have a ge sisde by side model#gss25rgma ww. the fridge/freezer is working good, but now not making ice, it has started to make a really loud humming type sound if the doors are left open to long than...
Sounds like a evaporator fan motor problem. However remove rear panel and if slight frost on top of evaporator replace motor if not post back or call professional
Oct 02, 2017 | Refrigerators
I have a LRFC22750TT model Lg Refrigerator. When the doors are closed the lights inside stay on. VERY HOT! Dangerous! Any advice?
Hi!!
Check on the cabinet door frame for the light switch. Press it all the way inn and the light should go off. If this happens, the door is not pressing far enough to turn the light off. To fix this, place a self sticking plastic pad, like the ones you use on glass tables, where you set the glass, on the spot where the switch makes contact with the door to give it a little more reach. If the light do not turn off when the switch is pressed, the switch is defective. You can get a replacement at any Appliance Parts store for about $5.
You'll need the Make, Model and probably the Serial No. of your unit.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 19, 2010 | LG LRFC25750 Refrigerator French Door
There is a low pitched howling/humming noise coming from the freezer compartment. The noise is not constant but cycles on and off every 15 minutes. It will make the noise for a period of time then suddenly...
The evaporator fan motor likely needs replacing. The fan is located behind the rear panel in the freezer section. It may just be loose or rubbing but usually it just needs replacing. Here is a link that should help Evaporator fan replacement You can also enter your model # for diagrams and illustrations of your specific model.
Nov 17, 2010 | GE GSH25JSRSS Stainless Steel Side by Side...
I have a bottom freezer kenmore refrigerator model 596.72253200 and its making a grinding sound coming from the freezer. i found out that when the light its off on the freezer its when the noise starts
The noise your hearing is the evaporator fan. This is a sign of an automatig defrosting problem. Here is what you can do to prove that it is NOT an evaporator problem and most likely an automatic defrosting problem:
(MANUAL DEFROST)
1 Empty the freezer contents
2. Unplug the refrigerator
3. Place a fan blowing into the freezer section for about 2 hours.
(This will make a dripping water mess so be ready with the rags and the mop.)
4. After 2 hours wipe up the last bit of water mess.
5. Plug in the Freezer
6. Load freezer contents.
7. Listen for grinding noise.
My bet is the grinding noise is gone. However if you still hear it the evaporator fan motor has bad bearings in it.
The evaporator fan motor can be found here: (Item 18)
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-59672253200/0582/0161000/M0210209/00006?blt=06&prst=&shdMod=
If the noise is gone keep an eye on the unit after 2 days because if there is an automatic defrosting problem the noise WILL repeat.
The defrost control is item 13 this link: (Backordered)http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-59672253200/0582/0161000/M0210209/00003?blt=06&prst=&shdMod=
Part number is: 12566102
I did find it in stock here:
http://www.pcappliancerepair.com/part-detail.php?affiliate_id=seabreeze&item=12566102&brand=WPL
There can be other reasons for not defrosting properly but the control is the most common failure.
Thanks for choosing FixYa.
Kelly
Sep 07, 2010 | Refrigerators
I have a 1976 model Sears Coldspot that is making a girgling/grinding sound from the freezer area. I remove the fan cover plate and the fan was rotating ok but every so often it would hesitate and slow...
if the temp has risen,check and make sure its not stuck in defrost mode,if it is advance the defrost timer ahead so the compressor again starts and runs,the only other thing would be the motor that you said is slowing down is getting noisy bearings and make that grinding sound,the gurgling noise could be just freon/refrigerant moving through the evaporator coils in the freezer
May 14, 2010 | Refrigerators
Our refrigerator just suddenly started to make this loud grinding sound..it appears to be coming from the freezer side. I turned off the ice make and reduced the freezer temperature but it still keeps...
This could be a failure of the evaporator fan. Also maybe some ice has formed from water dripping from the ice maker and had now produced an icicle which could be hitting the fan blade of the evaporator motor. Remove back cover to the freezer/fan and check the fan operation while it is running.
Mar 29, 2010 | KitchenAid Refrigerators
Noisy Motor?
Hi, It is the evaporator fan motor/blade hitting something. Remove the rear panel inside the freezer section and see what the fan blade is hitting.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Jul 27, 2009 | LG LSC26905TT Side by Side Refrigerator
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Jan 10, 2008 | LG French Door Cabinet Depth Refrigerator...
Refrigerators Logo
101 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
