Question about Fedders D Chassis A6D24E7A Air Conditioner
Fedders Window unit
Fedders A3D18E78_A , cools fine for bout 5 to 10 min, comp suts off hard, when try to start busses, wait 20 min, starts an cools for 5 min approx , all over again. Is cap for start only , or is it run also?? is part across cap supposed to be hot?? Is it comp, part, or cap. No signs of freeze, unit clean, fan starts an runs fine. Dont have amp probe for comp
Jim
  • 981 Answers
The capacitor's for running, too. The resistor across the capacitor is supposed to be warm but not hotter than boiling. Just disconnect the capacitor and check for a short if you suspect it; but it would be warm someplace.
The timer unit is usually reliable, but if it permits a thermal cutout after 5 min. and the cutout device is a little skittish, it could be either that cutout or a hot-side cutout (or thermostat) failure. Replace, don't bypass.
Posted on Oct 11, 2008
I have a fedders window ac unit 110 model A6X06F2A works fine for about 10 mins the the fan stops
i would try to oil bearings on motor. that failing replace run capacitor. motor must be getting hot.
Aug 01, 2015 | Fedders Heating & Cooling
The Fedders window unit A/C is making chirpy bird noises when it is first turned on for about 20 min. or so. What is the cause?
Usually a dry bearing somewhere. You need to fix it. If it is in the compressor rather than the fan, it is probably uneconomical to repair. It is better if the chirping STOPS after 20 minutes rather than STARTING after 20 minutes. Heat and use is fixing the problem for you.
May 18, 2015 | Fedders Heating & Cooling
My 1995 honda civic lx will run good for 20 min or so then dies and dosent want to start for about an hour then will start fine but then after bout another 20 min i have the same problem please help
possible cause is the fuel injection relay,located under the driver's
side of the dashboard or the igniter in the distributor is going bad.
Nov 29, 2012 | 1995 Honda Civic
I have an HP Pavilion 8113cl the problem is power. Starts just fine til window screen appears then shuts off. I can go into the bios sut as soon as it displays the machine shuts off. I've tried other
a notebook
well take out the battery , large one
run ok now/.
if bios does dead, that is POWER iSSUES.
BIOS never goes dead unless
1: POWER LOSS. (battery it does, try a new power pack )
2: OVERHEATED. clean out the dust lint yet?
3: Or far worse... (lots)
Jun 28, 2017 | HP Pavilion Computers & Internet
Signs of a bad compressor or condenser
plug this unit into a receptacle with a lamp also in the recept. unit will try to start the lamp will dim for a couple seconds and go back bright unit wont start maybe fan but no comp. sit and watch a few minutes later lamp will go dim again then back to bright, this is a classic low tech way of confirming the comp is trying but not working possible bad run capacitor, much cheaper than new unit
Aug 11, 2009 | Fedders A7DH65B2A Dehumidifier
Comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
FEDDERS D CHASSIS A6D24E7A
Oh, the compressor motor's borked or overworked and overheating, or its capacitor failed short (perhaps the motor is shutting off from thermal shutdown...but you get to find out whether that's so. Be safe.) Alternately the temperature sensors have gone touchy on you. Once you gently vacuum it clean, try keeping incandecent bulbs in series with the compressor to get an idea of how loaded that thing is as it runs for those 5 minutes or so; the load might change more than you expect, just pay attention.
Hopefully you won't have to replace the compressor or motor; but it's doable if you're a certified technician with like equipment (so you can handle the refrigerant decently.) Most shops will streamline a bunch of similar jobs together to cut the waste and setup time.
Bigger conditioners are so much more efficient than little ones...syndicate the A/C?
Air conditioner problem
You may have an extremely intolerant cold control, a weak gaurdette on the compressor, a compressor motor winding issue, or maybe an oversized unit for the area you are trying to cool.
May 30, 2008 | Heating & Cooling
Fedders D Chassis A6D24E7A Air Conditioner Logo
295 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
