MY TV MODEL AV-48P776 WILLNOT COME ON MADE A LOUD POP
  • secondsight Apr 03, 2009
    Ours did the same thing. It made a pop, then went off. We shut the power off and it went back on. About 20 minutes later, it did it again. Now the light that lets us know the TV is on, was flashing. But the picture won't come up. It is making a hissing noise, like when you are trying to light a stove burner, then shuts off. I am hoping we can fix it....with the economy, don't know if we can afford another TV...Please help!!! Thanks
  • 5,568 Answers
That loud pop might come from two different sources-
- The catastrophic failure of an electrolytic capacitor (not exactly rare) and is frequently accompanied by a fairly strong odor.
- The failure of a high power semiconductor such as a larger transistor or diode.
If you are adventurous, pull the plug from the wall, expose the innards and look closely at the bigger components you see.
Electrolytic capacitors are mostly cylindrical in shape and the ones likely to fail ludly are mounted perpendicular to the board.
Look for any with distended (bulging) tops or even split open.
Sometimes the electrolyte with form deposits around the case.
Power transistors and diodes are nearly always black epoxy cases with fairly thick leads extending through the board.
Transistors that work hard will be mounted on aluminum structures called 'heat sinks' that attempt to carry off the heat produced by the part.
Either of these may blow a hole in the epoxy case that is quite visible.
Locating the part is only a first step.
If you plan on doing this yourself, you will have to search for service info to find the part numbers of the failed parts and even if you replace those obviously defective, they may fail again because of undiagnosed problems elsewhere.
If you do find any, an honest tech will know why they probably failed and to look for the reason before replacing anything.
Posted on Jul 13, 2008
How do i get my HDMI to work on my JVC model av-48p776
Please make sure your TV in on correct channel by pushing INPUT and select [Digital IN]
Jan 31, 2015 | JVC Televison & Video
How do i find HDMI on my tv
Look on your remote for an "input" button, keep pressing until you get to "digital in" this is HDMI input!
Jan 12, 2015 | JVC Televison & Video
I look for the Hdmi with remote going through input and can't find
Check out this page
http://pdf.textfiles.com/manuals/STARINMANUALS/JVC/Archive/AV-48P776,%20AV-56P776.pdf
Could be that the pixels on the Ipad are set to high for the TV at the bottom left it shows what the pixals are accepted.
May 01, 2014 | JVC AV48P776 48" CRT TV
Loud popping noise tv
EHT arcing takes place. Never switch the TV on, until this fault has been rectified. Doing so, will make too many other faults to occur. Contact any service technician.
May 23, 2013 | JVC AV-35750 35" TV
JVC AV-48wp55 Made a loud noise and went dead instantly.
WELL IF IT WAS A LOUD POP,YOU NEED TO REPLACE THE FLYBACK TRANSFORMER,GET THE MAKE AND MODEL # AND DATE OFF THE BACK OF TV, AND CALL MATS ELECTRONICS #1-800-628-1118
Feb 15, 2010 | JVC AV-48WP30 48" Rear Projection...
Albert
albert
thaks for you i.m
I found the solution I repleased coil ( L531 ) and the tv looks like new
Nov 23, 2008 | JVC AV-48P775 48" HDTV
JVC 48" AV-48P776
no se ve bien los colores jvc 48 776
Nov 02, 2008 | JVC AV-48P775 48" HDTV
Jvc av-32fa44 tv--loud pop, then off and won't turn back on. buy new?
Its the power cap mine did the same thing about 11 months into daily use
Oct 24, 2008 | JVC AV-32FA44 32" TV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
