Question about Linksys EtherFast Cable/DSL Router
Has router failed?
7/13/08
Yesterday both home computers on linksys etherfast cable/dsl 4x (wired) could no longer get online. If I bypass the router, then my computers can get online. The indicator lights on router indicate it "sees" the computers and the computers "see" the router (if I shut down the router, my computer "announces" that it lost the connection and when I power the router back up the message goes away). I've also reset the router for no change. I have Comcast cable. Everything I've checked from the IP address to speed seems okay. Could the router be caput and needs replacing?
Thanks
Blake Gallagher (blakegallagher@comcast.net)
  • 928 Answers
The first question that needs to be answered is if your computer still gets an IP address from the router.
First reset the router.
Press the reset for 30 seconds then let go and then pull out the power. plug the power back in.
On the computer wired to the router.
1. Click start then run then type in CMD
2. Type in IPCONFIG
3. Check if you still get an IP.
Posted on Jul 27, 2008
    New Friend:
    Problem Solver:
  • 6 Answers
You need to find out if you have connectivity to the router from each PC and if each PC can still contact the other PC. This will verify that at least your physical layer connections, (the cables, PC's and router) are all connected and functioning at at least IP and DHCP level. Do this from all computers, you said you have 2? Reset router, (unplug it for 15 seconds then plug it back in), first, then reboot/reset/restart both PC's or you can just type at a command prompt on each one and type: IPCONFIG /RENEW ALL then IF you get an IP you should see if you can ping the default gateway for each computer and each computer. If you are not computer friendly just do the restart/reset/reboot thing. Once you have finished those steps do an IPCONFIG command and this will tell you your Default Gateway, (your router's IP address, and your PC that you ran the command from IP address.
Then use the PING ***.***.*** (the *** need to be replaced with the ip for example 192.168.0.1 or whatever ) command to ping your router(default gateway), and your other computer once you know it's IP as well. IF you get back 4 lines saying <10 msec response then all your equipment is wired find, and your router is also at least functioning at DHCP/IP level of the OSI troubleshooting model. Please come back and let us know if that's working or not, then we can move to the next steps.
If you have any questions feel free to come back here and comment or contact me. I will follow this question/problem so I will check in often.
Regards,
Jon Caldwell
Senior Technology Specialist
SME in 5 subjects at least (Subject Matter Expert).
Posted on Aug 14, 2012
Router pasword
Default user names:
  • Linksys BEFW11S4, WRT54G: admin
  • Linksys EtherFast Cable/DSL Ethernet routers: Administrator
  • Linksys Comcast routers: comcast
  • All other Linksys routers: [none]
Default passwords:
  • Linksys BEFW11S4: [none]
  • Linksys Comcast routers: 1234
  • All other Linksys routers: admin
Dec 07, 2010 | Linksys Wireless-G WRT54G Router
My new linksys router BEFS41 can't connect to a cable modem that is working. when computer is plugged direct to cable modem it works. Why can't it connect to the router?
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 28, 2010 | Linksys EtherFast Cable/DSL Router
My Etherfast cable/dsl router keeps getting disconnected although my cable modem says still online. What's wrong with it?
Base from the description of your problem this is a firmware issue on your router and to correct it will be better if you do a firmware upgrade on it , you can follow the steps from this link on how to update the firmware of the router.
http://www.fixya.com/support/r3810070-upgrade_firmware_linksys_routers
Jul 27, 2010 | Linksys EtherFast Cable/DSL Router
Dsl goes out when i plug it up to router.will comunicate between computer but no internet
Are you able to go online when connected to the modem ?
IF you are able to go online when connected to the modem.
Check the settings of the router.
You will need to access the set up interface of the router.
Click Here to know more about the router set up
Oct 28, 2009 | Linksys EtherFast Cable/DSL Router
TRYING TO HOOK UP ANOTHER COMPUTER
put the internet cable and ethernet cable in lan port then try to ping the google or yahoo or something else like that start-->run--->ping google.com -t
May 19, 2009 | Linksys EtherFast Cable/DSL Router
Connectin a linksys Befsr41 wired router to a Motorola 2210 modem
do one thing change the ip address of the LAN in the 192.168.2.1 in the router then you get it after that configuration you done right ok
Apr 14, 2009 | Linksys EtherFast Cable/DSL Router
Router doesn't recognize my computer
You check login in your modem maybe your setting get changed...
Jan 31, 2009 | Linksys EtherFast Cable/DSL Router
Problem with post forward
I HAVE ONE OF THIS ETHERFAST CABLE/DSL ROUTER BUT I CAN INSTALL...CAN YOU HELP ME????? PLEASE
Feb 03, 2008 | Linksys EtherFast Cable/DSL Router
Linksys EtherFast Cable/DSL Router Logo
73 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
