Question about Roper RAS8445KQ Top Load Washer
Kenmore 90 series agitator problem.
MY agitator is not spinning since a sheet wrapped around underneath it. I had pull a lot to get it untangled. Could the have come loose when I was pulling on it causing it not to turn? Could this be an easy fixing problem of having to re-tighten where it attaches?
  • 550 Answers
Usually it is a gearbox drive coupling, designed to break on exceptional loads
whirlpoool 285753, parts common to whirlpool roper ge kenmore and about a dozen other brands.
dissassembly instructions vary slightly between models
  • remove trims from ends of control panel
  • remove scres under trims
  • raise control panel and flip it over backwards
    (note: do not dislodge air tube from level selector)
  • remove brass retainer clips
    (note: position for reinstall)
  • remove lid switch connector
  • remove lid and body
the motor and gearbox are now exposed
  • undo bolt(s) holding spring clips to pump,
  • remove spring clips holding pump to motor(note position for reinstall)
  • unto bolt(s) holding spring clips to motor
  • remove spring clips holding motor to gearbox
  • there will be a plastic 3 legged 'spider' on the gearbox, and one on the motor, and a rubber ring with 6 holes that match the positions of the legs
  • remove the ring and spiders
  • take the ring and spiders to the local parts guy and get replacement,
    (Note the local parts guy will have the replacement, it is common to ge, whirlpool, roper, kenmore, new maytag, frigidaire and many others.)
  • use a piece of dowel, to hammer the center of the spider to the input shaft of the gearbox and the motor shaft,
    (note dont hit the legs they break.)
    (note: new spiders have metal center hubs, this is a common failure and the replacements have been strengthened)
  • turn gearbox shaft 1 leg up 2 legs down
  • turn motor shaft 2 legs up 1 leg down
  • insert new rubber ring over gearbox spider
  • insert motor into rubber ring
reinstall springclips
pump
pump springclips
body
control panel
in reverse order to above
gearbox coupling ~$17.00
time ~25 minutes, but I do 3-4/month
Posted on Oct 02, 2008
Clothes & sheets get wrapped in agitator and it makes a loud noise in my Whirlpool wtw4800xq1
Here is a video on how to change a part that could be part of the problem, the video shows how to remove the agitator so that you can remove the clothing that is jamming the machine, http://www.repairclinic.com/PartDetail/Whirlpool-Washing-Machine-Agitator-Repair-Kit/285809/470910?modelNumber=WTW4800XQ1&ss=a11b5d956381&mr=1
Jul 30, 2016 | Whirlpool Washing Machines
I have Kenmore 90 series Model 110 20902 990. I was washing sheets and the agitator got jammed. I removed everything and now it will not spin. There also is a clicking sound. Is the transmission blown or...
The coupling below the tub and agitator has broken. the coupling hooks the motor to the transmission. Very easy repair and parts are cheap, around 20.00 for the part. While your at it get a set of agitator dogs. These are plastic tabs that go in the agitator, they are what causes it to agitate in one direction. These are also only 10.00 and it will save you a service call later. There are many posts and instructions on this repair and the best thing is you can do it yourself with little tools!
Feb 05, 2011 | Kenmore Washing Machines
Kenmore 90 weak spin and agitation, good coupler,
go to www.searspartsdirect.com put in you model number and you can pull up a explode view of the transmission.
Apr 13, 2010 | Kenmore 15864/15862 Top Load Washer
Agitator does NOT spin along w/ drum during spin cycle
If this is the old style that uses a belt, it is not worth fixing. But the problem sounds like the wig-wam is not functioning properly. Most of the time it was a wire broken since it moves back and forth constantly.
Jan 28, 2010 | Kenmore Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Laundry is trapped under the base of the agitator.
Im not very familiar with that type of top loadign washer,,, but on most agitators there is a bolt that runs down the center of the agitator, connecting it to the transmission/gearbox. Usually there is a cap, or softner dispenser that can be pulled off, revealing this bolt.
Mar 13, 2009 | Washing Machines
Kenmore Washer 70 Series - sheets stuck around agitator
The transmission probably stripped the worm gear that drives the drum - you would have to crack it open and take a peek.
Nov 24, 2008 | Kenmore 15864/15862 Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
274 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
