I have a Frigidaire FWS1339AC 4 years old top load washer with a bad transmission would this still be under warranty
catriver
  • 878 Answers
SOURCE: Frigidaire Stackable Front Loader Washer
Jane, check to make sure that the drain hose has a air gap in the drain. Sometimes you will get a siphoning effect if you don't have the gap or it is pushed down to far in the drain. If this is not your problem, it's probably a timer issue...Catriver..post back
Posted on Oct 04, 2006
RJTech
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
  • 156 Answers
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Posted on Mar 03, 2008
  • 156 Answers
SOURCE: Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Posted on Mar 06, 2008
  • 1073 Answers
SOURCE: Frigidaire Washer machine with burning smell
burnt belt, tight center tub bearing, motor going bad, loose idler pulley spring, wiring issues at the motor, a lot of could bees
Posted on Apr 12, 2008
My front load washer frigidare door is rusty acsess door is rusted off its only 6 years old
Thank you for your post, debra!
I understand that the front of your Frigidaire washer is rusted. Typically rust is not covered under the warranty and in most cases, the door will more than likely need replacing. Could you please provide me with your model number? You can normally locate your serial tag (which lists your model number) on the upper front interior of the door frame on a front load washer. If you own a top load washer you would normally find the serial tag on the inside of the lid, on the right side. Once I have that information I can provide additional information for your washer. -Matt
Aug 13, 2014 | Frigidaire Washing Machines
Frigidaire Top Load Washer Won't Agitate FWS645GFS1
i guess you may be right
or maybe the motor
is not rotating with the ussuall speed pls inspect it..............
and ask for a technician .......
Sep 15, 2008 | Frigidaire CWS3600AS Top Load Washer
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
It wont start washing or spin
MIne had the same code. It is the error code for the motor and control board. The book that tells you how to read the code is under the washer behind the front panel. My washer was 4 1/2 years old and was shot. To repair this was $479 for parts and labor, I replaced with a new Amana front load washer for $496.00. Glad I had AHS home warranty only cost me $60.00 for the service call and they sent me a check for a replacement. I probably would not buy another Frigidaire, because a washer should last more than 4 years. Good Luck.
Jan 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Same problem as others
If the unit is less than a year old it is still under warranty,call Whirlpool you have a bad central control unit.
Sep 20, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Bearing is shot
Probley not but check manuel. Transmission bearing did have longer warrenty 3 to 5 year ago.So have alok in maneul.
Mar 10, 2009 | GE WJSR2070B Top Load Washer
Motor runs, but no spin.
You don't list model number so this will be a bit generic for Hotpoint top loader. If the motor spins but the belt is not moving: With power off, manually turn the large pulley the belt goes around, just a revolution is enough. Spin is CCW, but you may have to try CW (agitation). Now set turn the washer on spin again. This may unlock your transmission, but unfortunately is usually only a temporary solution. If the machine was manufactured prior to 1-1-06 and still under five years old, the transmission may still be covered under warranty. Check the back pages of your owner's manual. (labor would not be covered) If too old / not covered, I'd invest in a new front loading washer. The LG's are #1 rated in Consumer Reports and are direct drive (with a 7 year warranty on the motor) so there is no transmission, clutch, belt, or pulleys. You don't have to get the top of the line model, all LG's are direct drive and very good. Other front load machines, although not DD, will also use much less water than your hotpoint and spin out twice as fast or more, reducing dry time and dry cost. I know this wasn't what you really wanted to hear (bad news), so don't bother rating this "solution". (don't want my rating to go down just because I told someone bad news about there machine.)
Oct 05, 2008 | GE Hotpoint 2.7 cu. ft. Washer
Washer warranty
Red Flag !! 1 year now instead of 5 year Warranty .
I'd stay far clear from purchasing any model washer from Frigidaire!
Any one think differently?
Jun 12, 2008 | Frigidaire Washing Machines
Ok final Question
If this is a frigidaire, when the washer has a load in it, as the agitator agitates the tub should move about 1/8 of a turn. Meaning that for 8 agitations the tub should make 1 revolution. We call this indexing in the appliance repair world. If the tub is making 1 revolution in 4 agatations or 1 revolution in 1 agitation, the transmission is bad. This should have a 5 year warranty if purchased before 2006. You will also need a tub seal. Hope this helps
Feb 13, 2008 | Frigidaire FEX831CS Top Load Stacked...
Agitator will not move
Jac, my suggestion is this. The "reverse" gear in the transmission has locked up. The burning smell is coming from the belt. The motor is trying to spin the belt to turn the tranny but it won't turn  'cause it's locked up this causes the belt to burn.
If it's less than 5 years old, the tranny is under warranty. Contact Frigidaire and give them the full model and serial number and schedule a repair. (ask them to bring a belt with them when they come. you'll need one.)
Oct 11, 2007 | Frigidaire FGX831CS Top Load Stacked...
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
