Question about Whirlpool ACC108PS Air Conditioner
Fan does not run
The air conditioner has been running fine...not but a couple of years old.. this is the first year we have really had to use it. took the filter out to clean it and left it off all night.. when turned on this morning the motor and compressor kick on but the fan does not..any suggestions
  • tooke1973 Aug 27, 2008
    I have the EXACT same problem. Can anyone help??????
  • 30 Answers
Check out Selector Switch or Fan Motor Capacitor if ok then check Fan motor Winding
Posted on Feb 01, 2009
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Is it more expensive to run the central air on auto or in the on mode
Bridget, running the fan on all the time will increase air movement making you house more consistent on temp. As far as using more energy, as you stated your unit is 20 years old the fan is not a high efficiency ecm or even a pcm motor so it will use more power and hasten its demise. I would not do it unless unit is much newer and you really feel the difference.
Jul 14, 2012 | Heating & Cooling
Fan runs but compressor won't start. Compressor tries to come on every couple of minutes, dimming lights when it does, then stops. The other unit starts and runs just fine. The problem started just...
You could start by checking the capacitor. Then use an ohmmeter and check the fan windings. Hook one meter lead to com lead. Then hook the other meter lead to the run lead and then the start lead, reading the resistance each time. Then read from each to ground (compressor case). You could also use an ammeter to check the current draw when it starts. Hopefully it's just the capacitor.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
I have an AP450Z unit, it is 2 years old. When I switch the unit to cool it runs for a couple minutes then the entire unit shuts down. I can run the fan with no problem.
you must check the condenser fan make sure its running if ok then clean the condenser itself. take a water hose to the fins and clean them from front to back with the power off to a/c unit
Aug 29, 2009 | EdgeStar AP450Z Portable Air Conditioner
Fan works but not blowing cold air
Is the compressor running? If it is then you are probably low on refrigerant and needs to be leak checked and recharged.
Jul 16, 2009 | Frigidaire FAC125P1A Window Air...
Outside a/c fan quits but compresser still runs
it sounds like the fan is over amping itself and shutting down on thermal overload check the amp draw during running time and compare it to the sticker on the outside panel it should be running .9 amps, and it will over heat if it runs around 1.2 amps or above
Jun 21, 2009 | Goodman CLQ36AR49 Air Conditioner
Suddenly stopped cooling
Sounds to me like the run capacitor is bad. It is a dual one which means runs the fan and the compressor. No big deal capacitors are only 10 bucks and easy to replace.
First turn off the electricity to unit at breaker would be best. Next after you open the access panel locate the capacitor and make a note which wires go where one side is marked fan the other is herm. in the middle is comm. Take the old one in and get a new one same size and reinstall. Now parts only have one year warranty but they should have a discount on a person that bought a unit from them if you talk to them and tell them how can this happen only 2 years old. you know the story they might just throw one in for free to keep good business practice. Let me know how it goes. ken
Apr 16, 2009 | Intertherm P3RA-060K Air Conditioner
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Whirlpool ACC108PS Air Conditioner Logo
195 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
