I would like to bring my system back from the first time it was switch on.
  • Enrique Barrios May 11, 2010
    Hi.
    Maybe you think the experts are real wizards, thats only a way to call somebody with some knowledge.( just kidding).
    How can we know what is your Operating System, is it Windows XP ?, Window Vista ?
    You will have to be more specific to get some help.
    Regards.
  • IQUIT May 11, 2010
    What make and model is the system?
  • 3,940 Answers
If you have a Dell, you can follow this link.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=3E48AE3870775D64E040A68F5B2877D4&doclang=en
If you have HP or Compaq system, the system may have a Re-image setting in the setup or a re-image disk may come with the system.
Posted on Jul 14, 2008
  • 781 Answers
Try a complete reinstall of O/S
Posted on Jul 13, 2008
I have a 16kW Generac Guardian Generator with a 200 amp house service RTS panel (installed 2007). Last night the power went out and the generator started but the unit did not switch to use generator
The problem with the repair service is another matter. Emergency generator and it's switch gear are there for emergency purposes. It has to be exercised periodically. The switch gear should have a toggle switch to simulate a power outage. the switch cuts power to the sensor sensing power from the utility company. This tells the switch gear that power was lost, start the engine and switch over to generator power. Run for a period where engine reached running temperature and switch back to stand by to shut down. Do this periodically, and be grateful the event was not a disaster. Think of your back up electrical system as the spare tire of your car and similar equipment and enjoy your investment. Good people brings you happiness, bad people brings you experience !.
Nov 11, 2014 | Generac Guardian Electrical Supplies
Faulty tablet each time i turn it on it switches back off.
Under the sale of goods act you can return it to the shop or the manufacturer
Feb 13, 2014 | Computers & Internet
System lockout code keeps flashing and furnace won't start
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Jan 21, 2014 | Heating & Cooling
Philips hts8100
short circuit in the pcb in the soundbar if u have warranty than make rma for repair, or bring it back to the dealer where u buy it
Nov 23, 2013 | Audio Players & Recorders
Put new batteries in exit signs but the status light wont stay on green...it will switch back to a constant red meaning charging. What would be bringing the power of a new battery down all the time?
is the unit battery only or battery backup? if battery backup, the system is draining the batteries as it has no source of power.. if battery only there may be a connection problem or a faulty unit.
May 13, 2010 | Universal Battery Exit Sign Red Led ...
When switching on PC it does not boot up fully
Hi Craig
From what you are descrbing one of the background services is preventing start up from completing
Please try the following
1) Switch on PC
2) Continuoulsy press the F8 key until a start menu is presented, choose safe mode from this menu
3) Once safe mode has loaded up go to Start>Programs>Systems Tools>System Restore
4) From the system restore menu choose 'restore my computer to a earlier time'
5) From the calendar presented choose a date in bold when this fault wasnt happening and then click on next and follow the screen through
6) Let the system restore complete and it will automatically reboot and take you back to the mains windows screen
7) This should hopefully let the hung service be able to run
I hope this has been useful
Mar 10, 2010 | Dell Dimension 2300 PC Desktop
My 1997 dodge Neon will idle perfectly, however when I depress the accelerator it stalls and shut off the engine, most times it will back up,however will not until the engine has been off for a while.
Check your spark plugs.
Possible problem with fuel injection system
cloged fuel filter
EGR system malfunctioning
Intake manifold air leak
Check your fuel pressure
Feb 20, 2010 | 1997 Plymouth Neon
Wii console went dead... is there a fuse to reset the thing?
Try unplugging all the cords from the wii unit, wait about a minute or so, then reconnect the cords and power up. This should "reset" the system. A similar situation occurred with our system, and this was the solution we were told to try, and it worked. Good luck! :)
Sep 23, 2009 | Nintendo Wii Console
Time clock change on dodge ram navigation radio
Press "NAV" to go to the main navigation menu.
Scroll down and select "System Settings"
Scroll down and select "Clock Setting"
Make sure "Show GPS Clock" is selected with a red check in the box.
I had to switch "Daylight Savings" from "ON" to "OFF" in order to bring the time back an hour. I assume that I'll just have to switch it back to "ON" in the Spring in order to move the time forward and hour.
Nov 06, 2008 | 2006 Dodge Ram 1500
Black screen
Switch the machine off and back on again using the switch on the back. Turn the system on and keep your finger on the power button until it beeps a second time; this should bring you back into the XMB.
Aug 26, 2007 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
