Question about GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo...
Trash Compactor Removal
Can not remove trash compactor - it is built in and we have added hardwood floors and granite counter tops....we want it out the front is off and the bottom has been removed but we are unable to remove the rest of the unit what is holding it in place???
  • Anonymous Mar 20, 2014
    Compactor has electric sound but wiki not start up to compress
I noticed that my compactor attached to the countertop above it at the front, but that it is also possible to do the same at the back. Can you get access under the cabinet at the back of the compactor and check it out?
Posted on Aug 19, 2008
How remove stuck compactor from under counter?
Thee should be two screws from the compactor going into thE countertop. (You have to get a light, then shine straight up under the countertop. Remove the screws, then you can slowly work the compactor out of the hole so you can work on it.
Jul 03, 2014 | GE Profile GCG1580LSS 15" Built-In Trash...
Ge profile trash comapctor loud banging noice
You have something wrapped on the compactor screw assembly (The assembly is a threaded rod about 24 inches long and 3/4 inch in diameter. ). Most likely it is plastic bag or some other plastic. Pull the entire compactor out (remove the hold down screws first). Then look for the obstruction on the screw assembly, cut it off and try while not in the compactor hole to make sure it works.
Jun 18, 2014 | GE Profile GCG1580LSS 15" Built-In Trash...
I want to install a vinotemp Model: VT-TC32SB. Currently, there is a trash compactor in the space. If I pull the trash compactor out, can I just slide the fridge in place? The countertop and cabinets are...
Hi, It depends a little bit on how your trash compactor and cabinetry are currently set up. Some people have a tough time getting the trash compactor out/cooler in because of the lip that comes down off their counter. However, if you can pull one out, you "should" be able to just slide the other one in. Likewise, you'll need to be sure there is an electrical outlet available in the space. Usually, this isn't a problem as your new Vinotemp will plug right in where the trash compactor was plugged in. But in very old houses sometimes the trash compactor was wired right into the electrical. As long as your counter/cabinets were designed with enough room to move units in/out, this change should go smoothly for you. Best of luck!
Aug 30, 2011 | Refrigerators
I've got a GE trash compactor (GCG1580PSS). The door is stuck, presumably because the ram is stuck in the down position. If power is turned on, it will run until it shuts down (faint smell of...
Look up and down, may have an installation apparatus hooked into the counter top and the floor. Go to manualsonline.com to download owner's manual which should have installation information in it. Hope that helps..
Jul 19, 2011 | GE Profile GCG1580LSS 15" Built-In Trash...
Compactor ram stuck partially down & door open 2 inches. How do I get the ram to go back up & get the door closed?
We just had this same problem. Your problem is most likely abroken plastic gear found at underneeath the bottom of the compactor. Pull out the compactor and turn it upside down. Remove the bottom panel and that is where we found the broken gear. We were able to retract the ram and open the drawer by manually turning the drive chain using an ajustable wrench. Clockwise is compact, counter clockwise is retract.
Feb 03, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Trash Compactor Model GCG1500LOBB. the foot
I also found that after 2 years my GE Profile Trash Compactor (purchased in June '07), the pedal was hanging down on the left side. I searched the internet and called GE to no avail.
After a few attempts, I finally solved the problem by removing the screw on the left side and adding a metal "L" bracket, with the bottom of the L flush against the back of the front panel. That way, when you depress the pedal, the screw can't pop out of the metal it's attached to.
Dannys00
Dec 21, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo... Logo
412 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
