Dog walker on remote now no picture just saying weak or no signal
YES I DID FIX MY TV MYSELF. IT WAS JUST WORKING WITH THE REMOTE CONTROL. THE MAN I TALKED WITH YESTERDAY WAS TRYING TO SAY IT WAS IN THE CONNTECTION AND I KNEW IT WASN'T. SO PLEASE DO NOT CHARGE ME THE 14.99 CHARGE FOR HIS HELP, HE REALLY DIDN'T HELP ME FIX IT. THANK YOU RITA BYERLEY hattie19556@aol.com
Posted on Jul 14, 2008
How do Dog hunting collars work?
If you are referring to remote trainers' collar then please know that all remote trainers have the same basic 3 components: Remote transmitter, Collar receiver and collar probes.
The transmitter sends a radio signal to the collar receiver. Then, the collar delivers the stimulation to the dog through the stainless steel collar probes. The probes are located on the dog's neck and must have direct contact with the dog's skin in order to properly function.
Jan 14, 2013 | Hunting
My two year old son pushed a button on the remote and now our HD Samsung tv says Weak or no signal. We have tried everything including reseting it. Do you have a solution, please?
try going to the tv itself and push the source/input button. you should go to the correct source to get your picture back. try looking for the input or source button on the remote as well. that should do the trick -gab
Oct 18, 2010 | Samsung LN-S4092D 40 in. LCD HDTV
I hit a key on the remote and now the TV says, "No Program or Weak Signal." How do I go back to the picture?
If you are using the original TV remote it sounds as if you have pressed the input button on accident... try pressing the input button one at a time until your picture returns....
Good Luck....
Jan 12, 2010 | JVC AV-32D305 32" TV
Tv works jsut no pic black and white screen says weak or no signel?
If it says "weak or no signal", this means your are not showing the correct input or have no channels programmed.
To find the the correct video input:
1. turn On the device you are trying to see
2. press the [input] button on the side of the TV until you get a picture (wait 3 seconds between pressing the button)
You program the TV by accessing it in the User Menu.
Also, You may access the inputs using the TV remote. Each input button (V4 and V5) may need to be pressed muliptle time to access the picture . When you press this on the remote you will notice the input change from Composite 1, Component 1, S-Video. V5 will show composite 2 and component 2. Using the side panel allows youto scan all inputs in case you are not sure.
Jun 23, 2009 | JVC LT42P789 42 in. LCD TV
MENU PICTURE ON TV BUT NO CHANNELS
This is a problem with weak signal strength, You will need to find a better place to put your television so it can receive enough signal to operate correctly. If this does not solve the problem, you will need to check the satellite box for problems with receiving the signal from the satellite. You may need help from the satellite company to check the signal strength output and input levels to make sure its working properly. I hope this information helps you solve you problem with the loss of satellite signal in your television. Thank you for using FixYa and have a nice day!
Jun 18, 2009 | RCA DIRECTV Satellite Remote Control
The dogs rolled on the remote and the tv went to a blue screen and turned off. Every time you turn the tv on now it is a blue screen and says no signal and turns off after 10 seconds
This sounds as if when the dog rolled on your remote he has pressed the source button so that you are no longer on the TV cahnnel. The TV is looking for a different input eg. AV1/AV2/HDMI etc. This will give you a blue screen & as there is no signal the TV will switch off. Check on the remote for an Input or TV/AV or source button & make sure this is set for the TV signal.
Mar 22, 2009 | Vizio Televison & Video
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Dec 29, 2008 | JVC LT42P789 42 in. LCD TV
Weak or no signal message
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Jun 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Electro Med Services...
