When I push the power button or use the remote to turn the power on, the green light comes on and then goes off with the power after a second or two. The screen stays black and does not display anything.
Any ideas?
When I push the power button or use the remote to turn the power on, the green light comes on and then goes off with the power after a second or two. The screen stays black and does not display anything. unplugging for two hours no help. does this model have a reset button and if so where would I find it?
This behavior could be an indicator of power supply problems or abnormal current drain from elsewhere in the set.
Modern supplies are, by design, able to shut down if voltage or currents aren't within the design limits of the circuits they are servicing.
Without some hands-on it is not possible to isolate the problem unless one of the forums deals with a series fault.
If the set had a reset button, it would be located on the outside of it where the user could reset it.
The reset buttons one finds on some sets is nothing other than a very cheap kind of thermal circuit breaker that trips when current is above its limit.
These are kind of prone to failure themselves.
