Question about Fuji FinePix F700 Digital Camera
Hello My finepix s700 will not turn on i have put new batteries in and it still will not turn on!! Do you have anything that could help me??
  • Anonymous Apr 23, 2009
    I have the same exact problem. I purchased a brand new batter and my camera still will not turn on.
    Problem Solver:
  • 6 Answers
On switch broken?
Posted on Aug 19, 2008
My fuji finepixs keeps asking me to turn off the camera and turn back on-whatdo i do to solve this
Turn it off, remove the card and battery, leave it overnight and then replace battery and card. This may help - if not, it is probably a repair (expensive) or replace situation, I'm afraid.
Jun 15, 2016 | Fuji FinePix S700 Digital Camera
I put new batteries in my camera and it is still reading very low and then shutting off,what would this mean!
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Dec 02, 2009 | Fuji FinePix S700 Digital Camera
Camera
i have the same cam and had the same prob...only to realize that i was putting the battery in the wrong order....follow the diagram in the camaera when you open the battery door...it shows the position the battery goes in. Good luck, i hope this works out for you...it's a wicked camera, comparable to any and all dslr cam's out there..the quality is amazing..people will not be able to tell the difference with a dslr and the s700 quality.
Sep 06, 2009 | Fuji FinePix S700 Digital Camera
Need copy of manual for finepix s700 camera
Hello
OK, at the l;ink below you will be able to download the manual in PDF format free of charge.
Click HERE to navigate to download page.
Fell free to contact me if you need any further assistance.
Kind regards
Andrea
May 12, 2009 | Fuji FinePix S700 Digital Camera
Fujufilm S700 won't power on. New batteries and are in correctly. Battery door closed properly, however, the door covering the SD is broken in half. Will this cause the camera not to power on?
Yes it will. The door activates a micro switch that cuts power to the camera when open to prevent accidental removal of the card and loss of pictures stored on the card. You can bypass this switch with either a solder "bridge" or remove the switch and use a piece of wire to bridge the pads on the board.
Apr 19, 2009 | Fuji FinePix S700 Digital Camera
Fuji Finepix s700
I recommend to all my customers with AA battery life issues to try Energizer Lithium AA's. Virtually all battery issues solved. I think alkaline batteries are being manufactured poorly, these days, so even brand new they aren't great.
Mar 08, 2009 | Fuji Finepix S9600 Digital Camera
Fujifilm finepix s700 is not turning on
OK
First check the battery door to make sure that it is closed properly. If you have a media door (the door which covers where the media cards are inserted) make sure that is closed properly. If this is the case then check that there is no plastic broken off. The doors contact with microswitches which allow the camera to turn on.
On the camera there is also a playback button. (green triangle) If you hold this and the camera turns on then your power switch is faulty.
Failing all of this then put some power into the camera via an adapter. If the camera turns on then it is likelly to be a battery fuse.
In all instances you will need to send the camera to be repaired at the fujifilm service centre. Web address below.
http://www.fujifilm.co.uk/technical/camera_repair/
Dec 17, 2008 | Fuji FinePix S700 Digital Camera
Fuji FinePix S700 Problem
Try to put it on super macro and see if this will reset the zoom function.
Also try to switch between the settings that allow the digital zoom, as compaired to those settings that only allow optical zoom.
If these do not work, you may have a lens that has been dropped, or is stuck, and may need to be serviced. I have the S700, and have never seen this error before> good luck.
Jun 12, 2008 | Fuji FinePix S700 Digital Camera
It will not turn on
try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 21, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Fuji FinePix F700 Digital Camera Logo
110 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
