Question about GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo...
A built in trash compactor - how do we get it out?? We have added wood floors and granite counter tops since the installation of the compactor.....it is all apart we can not get the main unit to come free....what is holding it in the opening???
  • NanaLovell Jul 13, 2008
    Please.....I need help....not call GE!!!!! I don't need to pay for that advice!!!
    There are no legs....they were removed when it was put back after the floors were installed!?!?!? Any other ideas??
    Sergeant:
  • 260 Answers
Because trash compactors have to be pulled out to add trash on a regular basis, they have to be anchored in the rear to the floor and the wall to prevent them from toppling over every time you open it. Most likely these are the anchors that are still holding it into the wall. You will need to gain access to both sides of the compactor and to the rear. That probably means you will need to remove some of the cabinetry or countertop that you recently installed.
Posted on Jul 13, 2008
  • 6,487 Answers
1. Shut-down power to compactor unit. 2. Remove the trash bin. 3. Remove four plastic "button" in floor of unit to expose screw-driver access holes. (One hole at each corner of the floor of compacting cavity.) 4. Use medium size, flat blade screw-driver to retract the leveling screws until the pads touch the bottom of the unit. This action lowers the unit and should make it free to "rock back-and-forth". 5. Once free to move, it can simply slide forward from beneath the sink. Protect the floor because the sliding unit can damage the surface.
Hope that helps.........
var niB = document.getElementById("niBannerID"); if(niB && niB.style.display=="block"){ document.getElementById("q_answer").style.marginTop = (niB.offsetHeight+70)+"px"; } -->
  • 78 Answers
To remove a Built in Trash compactor, you are going to need to get the same materials of the Floors, and Counter tops. (Wood Flooring and Granite counter Top in your case). You can't pull it out, because the legs are catching on the floor, you are going to have turn the legs counter-clockwise. If you use a pair of plyers, it should help alot. If you have any other questions, I am glad to help. - CA
  • 1 more comment
  • Tyler Durden
    Tyler Durden Jul 13, 2008
    What is holding it in the opening, is the legs, you are going to have to remove them with plyers.
  • Tyler Durden
    What happens when you try to pull it out?
  • Tyler Durden
    Marked, copying it off of a site is not going to work.
    President:
  • 2,712 Answers
Could be a lot of reasons..I would recommend getting in touch with the manufacturer first..
  • Swilin Sampson
    Swilin Sampson Jul 13, 2008
    yes, go along CA92793 's lines..hes got a point there..
How remove stuck compactor from under counter?
Thee should be two screws from the compactor going into thE countertop. (You have to get a light, then shine straight up under the countertop. Remove the screws, then you can slowly work the compactor out of the hole so you can work on it.
Jul 03, 2014 | GE Profile GCG1580LSS 15" Built-In Trash...
I want to install a vinotemp Model: VT-TC32SB. Currently, there is a trash compactor in the space. If I pull the trash compactor out, can I just slide the fridge in place? The countertop and cabinets are...
Hi, It depends a little bit on how your trash compactor and cabinetry are currently set up. Some people have a tough time getting the trash compactor out/cooler in because of the lip that comes down off their counter. However, if you can pull one out, you "should" be able to just slide the other one in. Likewise, you'll need to be sure there is an electrical outlet available in the space. Usually, this isn't a problem as your new Vinotemp will plug right in where the trash compactor was plugged in. But in very old houses sometimes the trash compactor was wired right into the electrical. As long as your counter/cabinets were designed with enough room to move units in/out, this change should go smoothly for you. Best of luck!
Aug 30, 2011 | Refrigerators
I've got a GE trash compactor (GCG1580PSS). The door is stuck, presumably because the ram is stuck in the down position. If power is turned on, it will run until it shuts down (faint smell of...
Look up and down, may have an installation apparatus hooked into the counter top and the floor. Go to manualsonline.com to download owner's manual which should have installation information in it. Hope that helps..
Jul 19, 2011 | GE Profile GCG1580LSS 15" Built-In Trash...
Compactor ram stuck partially down & door open 2 inches. How do I get the ram to go back up & get the door closed?
We just had this same problem. Your problem is most likely abroken plastic gear found at underneeath the bottom of the compactor. Pull out the compactor and turn it upside down. Remove the bottom panel and that is where we found the broken gear. We were able to retract the ram and open the drawer by manually turning the drive chain using an ajustable wrench. Clockwise is compact, counter clockwise is retract.
Feb 03, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Trash Compactor Model GCG1500LOBB. the foot
I also found that after 2 years my GE Profile Trash Compactor (purchased in June '07), the pedal was hanging down on the left side. I searched the internet and called GE to no avail.
After a few attempts, I finally solved the problem by removing the screw on the left side and adding a metal "L" bracket, with the bottom of the L flush against the back of the front panel. That way, when you depress the pedal, the screw can't pop out of the metal it's attached to.
Dannys00
Dec 21, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
I'm having my kitchen counter tops replaced with granite. I have a GE Model GSD700 dishwasher that is now attached to the existing counter top. The granite counter tops will not accept having a dishwasher...
• Purchase and install the GPF65 side-mount
bracket kit if the underside of counter is granite
or a similar material that will not accept wood
screws. The GPF65 kit is available from authorized
GE appliance dealers.
Also note that any stainless steel tub models would be able to accomadate granite tops without a kit, and I beleive all Profile GE models come with the kit included.
Sep 27, 2009 | Dishwashers
Trash Compactor Removal
I noticed that my compactor attached to the countertop above it at the front, but that it is also possible to do the same at the back. Can you get access under the cabinet at the back of the compactor and check it out?
Jul 13, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo... Logo
249 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
