Question about Mitsubishi WD-52525 52" Rear Projection HDTV
WS65909 and no DVD device recognition
I bought a new DVD player with component video cables, plugged them in and when i go to the device menu the DVD player does not exist. Am AI missing something?
This can be solved in the setup, the dvde input needs to be enabled. It will be one of the comp inputs depending on which one you are using.
Posted on Jul 16, 2008
Could you tell me the steps to hook up my vcr & my dvd players to my tv. And what cables and or devices I need to accomplish this task?
It will depend on the devices. Most VCRs will have composite and S-video outputs. For this you will need either a composite audio/video cable (3 RCA plugs on each end: yellow (video) and red and white (audio)) or an S-video cable and a separate audio cable. The DVD player will probably have component video or HDMI outputs, depending on its age. The component video requires a 3 plug RCA video cable (red, green, blue) and a 2 plug RCA audio cable (red and white). Some DVD players have composite outputs as well. However, this limits you to an SD video output and isn't recommended, unless your TV doesn't have any HD inputs.
If your TV has one each of the appropriate input ports or 2 composite video ports, you just need those cables, assuming you have no other devices that have filled the inputs. Always connect the devices with the TV and the A/V components off. Match the color of the plug to the port. If you mix up the colors on component video cable, you may get a black&white picture. Some newer TVs use an adapter dongle to convert composite or component video to single port on the input board. Again match the colors at the dongle and then plug in the adapter. If your TV has shared composite and component signals, use the HDMI port output on the DVD player, if possible, or get a Audio/Video switch, like this: http://www.amazon.com/Panlong-Switcher-Composite-Selector-Consoles/dp/B00KXVBB3Q/ref=sr_1_24?s=audio-video-accessories&ie=UTF8&qid=1440632814&sr=1-24 .
Please add a comment with the make and model of your specific TV, VCR and DVD player. I hope this helps.
Aug 26, 2015 | Televison & Video
No color display when i play DVD thru component.
First, check the settings on the DVD player's setup menu for output. Make sure it's set to either Component or Y YB YR or YBPR, and not to "Video". If your settings are correct, check the component cable and make sure it's plugged in correctly on both sides, TV and DVD. If still having a problem, try a new cable.
Finally check the input settings on the TV, if you still have a problem, try using a basic Audio Video cable on the Video out of the DVD to Video 1 in on the TV. That's about as much as you can check. If all fails, if possible, connect the DVD to another TV to check for the same problem to determine if it's a DVD player problem or a TV input problem. Hope this helps!
Jun 01, 2011 | Televison & Video
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
I just bought a new dvd player and it references the hdmi which I know the tv does not have. Will it still work with this tv?
Probably, you'll just need the audio and video cables separately. Most DVD Players still have Component video (one cable with 3 video plugs on each end and the two channel (red and white) RCA audio. Your TV also has an AV input (one cable with a single RCA plug on each end - usually yellow for video, plus the audio cable) and S-video.
The component video is your best choice with modern DVD players if you can't use the HDMI port.
I hope this helps.
May 01, 2010 | Toshiba TN55X81 55" Rear Projection...
Hi, Just bought a 26" sony bravia tv. I don't use cable or satillite. I just need to find out what kind of cable I need to connect my panasonic DVD player to the TV and which port do I plug it into?
The best quality would be a HDMI cable, if your DVD player has a HDMI port on the back.
Any of the HDMI ports on the TV can be configured to take the audio over HDMI (digital audio) or over a separate rca stereo patch cable (menu option in the TV for analog audio).
So if your DVD has HDMI, just buy a HDMI cable and you're done. If you cannot figure out how to switch the audio input, there is no big harm in just installing a separate RCA patch cable between the two for the sound.
The next-best would be a component-video cable (Red/Yellow/Green) RCA cable, with a separate red/white RCA audio cable.
Alternately, if your DVD has a S-video port, that is comparable to component video. Then you would need a separate audio cable as well.
Last but not least, if your DVD player is ancient, it may only have a yellow video out connection, then red/white for audio. You then just need a standard yellow/red/white RCA component cable.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No video
The Denon does not down scale you can not plug a DVD or other device in to the Denon using HDMI and have it come out Component, if your projector only has Component video inputs you must use Component video connections from the DVD and Cable box to the Denon
Jan 02, 2009 | Denon AVR-3805 Receiver
I bought a new dvd player because the picture was blue and scrambled. The new one is doing the same thing. I am using component video cables. I tried new cables as well.
Try to move a bit the plug in your TV with your dvd and TV on, if the picture is changing, the connector in the TV need to be re-solded..
if not, some electronics component doing the video acquisition need to be replace..
How is the sound?
Dec 23, 2008 | Televison & Video
Mintek 2110 no component video
You need to change the Video out in the menu.
Press set up on the remote
move down to video out and select YUV output
it should now work
Aug 08, 2008 | Mintek DVD-2580 DVD Player
Cable Hookups
plug in RCA cables from the "Component Video Output" of the DVD to the "Component input" on TV
on the TV's menu switch to the video source of the Component Video you plugged in the DVD. you should see the DVD you are playing.
thanks for rating
Jan 14, 2008 | Toshiba DVR3 DVD Recorder/VCR
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
