Question about Rowenta Perfect Iron
Cleaning the bottom of my rowenta irom.
I thought that I had the right temperature for my syntheic tank. Well, when I touched the iron to the fabric the tank melted. How do I get the brown stuff off the bottom?
Wad up a large piece of wax paper, turn off your steam and "iron" the ball of wax paper. The gunk comes right off the iron and sticks to the wax paper.
Posted on Mar 03, 2009
    Scholar:
  • 70 Answers
Rowenta does sell a soleplate cleaner kit. But if you must do it yourself, I use nothing but Q-tips, a wooden orange/popsicle stick to genly scrape the tough brown stuff...and finish it off with "Dutch" cleanser, and old cotton sock, either dry or with a tiny bit of filtered drinking water. Do not use anything stronger, as the soleplate can be easily scratched.
Posted on Jul 14, 2008
Rowenta Pro Precision won't stop steaming until the tank runs dry.
Rowenta irons have a propensity for leaking. Most users do not add water to the tank but instead use a spritz bottle to dampen the fabric and then use the dry iron.
Jul 16, 2017 | Rowenta Irons
Cannot get black stains off with the cleaner kit from Rowenta that I bough at Bed Bath and Beyond. Used almost all of the cream and still not clean. adjina39@aol.com
Are you heating up the soleplate first to get it really hot, then put on an oven mitt to protect your hand, squirt cream onto a folded pad of clean cotton fabric, then apply to iron sole plate, rub over stained area gently, wait, then rub off. you may want to rub the whole iron sole onto a piece of waste fabric to remove the burnt bits. Itcan take a couple of goes to clean. The ironing press cleaning sticks work well too.
Nov 03, 2013 | Rowenta Irons
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
The temperature of the boiler is not controlled normally and the safety valve opens. I suspect that the temperature control sensor is not functioning properly, and if this is the case where can I find a...
see this causes and use the common sense. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
Sep 19, 2012 | Rowenta Irons
How to repair aan electrical iron
If the iron doesn't heat, make sure power is on to the outlet, check the electrical chord, and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical chord . Also test and, if needed, adjust calibration of the thermostat.
If the iron sticks to fabric, clean or repair the sole plate. If the iron stains fabric, clean the sole plate, clean the tank with a commercial cleaner, and use distilled or filtered water.
The tools you will need are
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial sole plate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
Please rate my solution.
Jun 25, 2010 | Rowenta Professional Luxe DM880 Iron
I need to replace the trigger that makes the irom steam. Where can I buy replacemnet parts
Here is where I get my parts here in SoCal:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Apr 01, 2010 | Rowenta DG-980 Iron
Need to clean my Rowenta
let warm up and spray a good oven cleaner on it and let sit for awail(turn iron off) then it should just wipe off!
Please rate this answer!
Jan 23, 2009 | Rowenta DG-980 Iron
Soleplate is dirty
Rowent sells a hot iron cleaning kit. It comes with a tube of cleaner, a piece of white terry cloth and a piece of cotton flannel. You spred some of the cleaner on the terry and iron it. Melted fabric and other grim clean right off the iron. Then you polish it up on the flannel. Good luck!
Dec 29, 2008 | Rowenta Perfect Iron
Rowenta Perfect Iron Logo
472 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
