Check all connections and make sure all devices are on. If the power was turned off during printing, cancel the print job. If the error does not clear, see your printer documentation.
plz check all the settings, language setting must be check , after that if the problem not solved then uninstall the driver and again reinstall the printer driver
PDFs are designed to print using Postscript language. The problem will occur with any non-Postscript printer. You can get better results on Windows printers by clicking on the "Advanced' button in the Print dialogue window. Then check 'Print as Image'.
hi there, you do have a ribbon cable problem, the white strip wire which is connected to the head of the printer. repalce the ribbon head cable and add some cleaning and lubrication on your printer machine. ty
Did you install ink and did you remove the tape from the cartridges?
