Question about Eureka Vacuums
The brush roll on my Eureka Bagless The Boss 4 dimension cleaning vaccum itsn't working. How do I fix it?
  • Anonymous Mar 13, 2014
    how to clean the eureka 169b brush roll
    President:
  • 1,673 Answers
Take either the plate over the brush roll off, if it doesn't come off, then the top cover comes off, should be 2 or 3 screws on the top to remove. Then you can get to the belt and brush roll. Check the brush roll, make sure the ends turn freely, if not replace it. The belt is either broke or stretched to the point that it won't turn the roll, replace it.
Posted on Jul 13, 2008
Eureka Boss Capture 8803AVZ Bagless Upright Vacuum smells like it is burning
First you need to checkl and make sure the roller brush is not jammed up and the belts is not slipping due to the brush not turning
Apr 30, 2011 | Eureka Boss Capture 8803AVZ Bagless...
The belt on my used Eureka Boss 5857 upright slips off the end of the motor shaft every time the vacuum is used. When I turn the brush roll slowly by hand, the belt walks toward the end of the shaft. It...
The brush roller could be worn and in need of replacement. Some Eureka uprights have a wire guide that prevents the belt from slipping off the motor shaft.
Apr 02, 2011 | Eureka 5856BVZ Boss Bagless Upright...
What is the cause of the loud noise in my vaccum it's a eureka boss bagless
If it's a rattling type noise, its possibly something in the fan assembly, including a broken off piece of the fan.
It could also be something loose near the roller brush, including a piece of the belt.
Nov 18, 2010 | Eureka 5856BVZ Boss Bagless Upright...
My boss model 5892 brush will not roll
This unit has a reset button on the side of the hood. Recline handle, turn power switch on, pressing down in carpet mode, press reset buttonon the side of the hood, the brush should turn on.
May 01, 2010 | Eureka 5856BVZ Boss Bagless Upright...
Eureka boss power plus
I had this same problem. The brush roll wouldn't spin, smoke came out, and it smelled like burning rubber. I changed the belt thinking that would fix the problem but it didn't, so I took the belt back off and checked the motor shaft in the back and found a whole bunch of hair wrapped around the shaft. Once I cut out the hair with some scissors and replaced the belt, everything worked like normal. I hope this helps.
Sep 01, 2009 | Eureka Boss SuperLite Bagless Upright...
THE BOSS SUPERLITE THE BRUSHES WON'T TURN
Check two things with this model: if the top slider button has been activated it will turn the brush roll on. If not then you'll have to remove the sole plate and check the sides of the beater bar - sometimes this will get jammed and refuse to turn because clogging of dust or tangled hair/carpet thread takes up the thread wheels at the sides. Sadly this model has a permanent toothed drive belt that can't really be replaced by the owner. However check the slider control on the top of the main body / handle first before doing anything - as you know it has a two option slider - switching on without the brush roll function and switching on with the brush roll activated.
Feb 28, 2009 | Eureka Boss SuperLite Bagless Upright...
BOSS 5851 Wide Track, 12 Amp
The top comes off to get to the belt and brush roll. Did you check the brush roll to make sure that the ends turn freely, or is one not turning, the belt is a lon life "U" part #61120A. The brush roll is what drives the vacuum, but if brush roll or belt is bad, then it won't drive it.
Feb 03, 2008 | Eureka 5849A Boss Bagless Upright Cyclonic...
Vacuum doesn't go into carpet mode
If the model number is 5892AVZ, either the brush roll is bad or the brush roll motor isn't coming on to drive the brush roll. There is a circuit breaker, make sure it didn't trip, reset it if it has.
Jan 31, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Belt
Turn vac over, take out 4 to 5 screws and the top cover will come off. The belt is a cogged belt #72393 and goes between the brush roll motor and the brush roll.
Nov 14, 2007 | Eureka 5892AVZ Bagless Upright Cyclonic...
Eureka 5849A Boss bagless upright
remove belt to brush roll and see if noise persists. if it stops, you probably need a brush roll. at least doing this will narrow down the fault area
Mar 26, 2007 | Eureka 5849A Boss Bagless Upright Cyclonic...
Vacuums Logo
154 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
