Digital Tv I am just wondering how would someone install a digital tv at home? Could you give my the steps and what I would need?
    Scholar:
  • 78 Answers
Hi georgeous,
Best Buy has partnered with CNET.com to provide you unbiased information and advice for your home theater needs. Visit http://www.bestbuy.com/site/olspage.jsp?id=pcmcat97200050014&type=category for topics such as HDTV 101, HDTV Glossary, Digital Living Room, and Plasma vs. LCD.
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jul 14, 2008
Why doesn't the ARC TV sound work through the HDMI cable? Is it because the KDL-52XBR7 only has the Bravia Sync and no ARC support?
Not all Hdmi cables have same capabilities. Check out:
http://www.hdmi.org/consumer/finding_right_cable.aspx
Mar 27, 2015 | home Audio Players & Recorders
The tv isvhf and uhf in otherwords no picture how to receive digital on anolog system or get a pic on my tv anologly
Only one av plug in maybe plug in your analog TV scanner into av slot I have one to wondering if antenna plug in none but av one slot maybe antenna into from analog digital stream or RCA analog might give me antenna to directly off my RCA digital box
Sep 16, 2012 | Vector Vec135 Tough Brite Storm Tracker...
Unable to listen to tv through the surround system
Your BEST TV-related audio would be brought in directly from each external source you watch, NOT the TV itself (if TV's were hi-fi we wouldn't need audip equipment), so, yes, digital audio is the ONLY way to go. Having plenty of connections on the TV is NOT going to give you HI-FI multichannel audio from all of them.
Jul 08, 2010 | Panasonic SCBT230 Theater System
Hearing my television through my home theater system
Without knowing anything about your TV receiver all I can assume is that the TV has a least an RCA analog audio OUT. Run that to any available analog input on the HTS. make sure the TV's audio controls (hidden in a menu somewhere) is set to Fixed so the TV volume won't affect the HTS volume. Then you can turn the TV speakers off and still listen through the HTS.
You'll only get stereo this way. Ideally, you would have a digital audio source for the TV audio signal.
Jun 07, 2010 | Insignia Digital-to-Analog Converter for...
How to hook up my TV,home theater system, and digital receiver
To guide you on the exact cabling, I need to know more details like the model of the home theater and the TV model ..
However, to keep the things very simple; All you need to know is the direction of the signal. Now, we want the sound signal to travel "OUT" from the TV and travel "IN" to your Home theater home theater so that the signal gets amplified and is heard through Speakers of Home theater system so the cables run from
"Audio OUT" of TV ---------> "Audio IN" of Home Theater
All the cables are color coded.
Now Similarly.. You want the signal to travel OUT of your camera and IN to the TV so that you can see the larger image and louder sound .. so.. connect the cable that you received along with the camera into AV/TV "OUT" on camera to corresponding "INPUT" color coded ports on TV.
Please let me know if that was too complex to understand and I would try to simplify that further.
Regards,
Srinivas.
Apr 03, 2009 | Canon PowerShot A430 Digital Camera
No sound from plasma to home theatre
First off it's always best to start from scratch when it comes to home audio. LoL. Many times I've been in this situation.
So with everything disconnected. You should have your HDMI, COMPONENT, RCA(R,W,Y)
HDMI and COMPONENT are the exact same thing and in all preference COMPONENT is far better thand HDMI for the pure fact that each wire is in it's own casing and insualted to avoid feedback from the other wires.
Anyways, with everything disconnected we begin
From you Cable/satellite box- Run your HDMI cable from you cable box to your HDMI 1 input on your tv.(If your speakers were to work on your tv you would automaticaly get sound and picture)
That should be all that you should be running from you cable box. Now that we have one thing running we go to the next thing.
From your TV run your audio out (RCA Red/White) to your amp. Usually your preference but more than likely your TV IN on your amp.
With your amp now set on TV, you should automatically get sound from your tv. and if your running an HD cable box even though your only running RED/WHITE to your amp, you will still be receiving Digital sound.
Most new amps Should have a digital input and if your running and 1080iUp this one RCA plugin will give you dolby digital sound from your dvd player to your amp. Then running a video rca up to your tv, will give you the picture, while the digital out on your dvd player to your amp will give you dolby digital sound.
It's a basic simple step to get sound. Like a continuing current. So just as long as you have your cable to -- tv -- home theatre. Everything should work. Otherwise I would go and check your cables and make sure they are not faulty.
I hope this confusing walkthrough helps.
Jun 23, 2008 | Panasonic TH-42PX60U Television
Samsung DLP TV Component Problem-HL61A750A1F
FYI only:
HDMI = High Definition Media Interface
DVI = Digital Video Interface
That kind of conflict (that's what it is) is tough for any one company to assist you on since it involves two manufacturers.
If you are very lucky, you might get help from a tech who has already stumbled across the same equipment complement.
May 21, 2008 | Samsung DLP HL-P5663W 56" TV
Windows xp mce
Do you have tv tuners installed and setup properly? Media Center 2005 is just the software, the computer needs to have hardware tuners in it and hooked up to external antenna or cable.
Feb 15, 2008 | Philips TV Tuner Video Capture PCI Card -...
Home Theater install
yes sounds about right what you are doing as long as you have 2 digital audio 'inputs' on your Bose to get the audio from the dvd player and cable box. Apart from your last part "I will then use Digital Audio from the Bose to the TV." The tv will only downrate the audio to two channel stereo, so its not worth puting audio through the tv as you only get stereo anyway, so might as well let the tvs speakers power it out themselves.
Aug 17, 2007 | Bose Lifestyle 28 System
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
Electro Med Services...
