Question about Philips Magnavox 27MS343S 27" TV
Magnavox 15" lcd says it has attention no signal
  • mmfoor21 Jul 13, 2008
    magnavox 15" lcd says it has attention no signal the TV is only 2 years old model # 15MF400T/37
  • Anonymous Mar 02, 2009
    when tv is turned on - the attention no signal comes on and it turns the power off
    I tried hitting the TV/Source button but no help
Had the same problem. The solution: My remote has a button labeled "TV/VIDEO". I must have accidentally pushed this button so when I turned the TV on it was searching for the signal from a VIDEO source. It couldn't find the signal so it's programmed to automatically turn off if no signal is received. All I did to solve problem was I turned TV on and before it could turn off by itself I pushed the "TV/VIDEO" button on my remote to switch it back to receiving TV signal.
Posted on Aug 15, 2008
Remote code for Magnavox 15MF400T 15 inch lcd tv
try=0019/0191/0711
if not google "remote code magnavox"
Nov 04, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Magnavox LCD HDTV starts on its own since last few months and sometimes it changes channel on its own. This problem happens intermittently and really apprecaite fix for this. This TV is 15 months old.
it either needs new front switch panel or new signal module, turn the tv on and disconnect the front switch board if it quits doing things on it's own you need a new front switch panel, if it still does functions on it's own you need a new signal board.
Sep 08, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Magnavox 37MF331D/37 keep asking for software upgrade
Your set either has a bad SSB (small signal board) or needs a software upgrade. Try the upgrade first by going to http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=FLAT_TV_CA&sct=LCD_LARGE_30_40_SU&grp=TV_GR&session=20090830171041_4.131.87.247&ctn=37MF331D/37&mid=Link_Software&hlt=Link_Software
Download the latest software release for your set then follow install instructions that are contained in the user manual for your set.
Jul 22, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
TV displays a "no signal message"
is there any picture at all ? if no signal message regardless of any signal input , ur ad board need to be change.
Sep 19, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Screen says attention no signal
Your TV is probably on the PC mode and you are not using it as a PC monitor.
You need to change the source by pressing the TV/Video button on the remote control or the SOURCE button on the TV itself. You may also just press the channel up or down buttons. Do this before the TV goes to standby mode (amber light) or while it shows the message: ATTENTION NO SIGNAL.
If it does not work, reboot the TV first and do this again.
May 17, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Need Help
check the cable connecting to the System unit!, it could have loosen up!
tighten it
Feb 15, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Magnavox 15" LCD TV
If the LCD only has coax, it will never display a HD picture quality. However, the Comcast HD Box will still display a picture using the coax connection. So, you could watch any HD channel, but the picture quality will not be high definition.
Jan 22, 2008 | Philips Magnavox 27MS343S 27" TV
Attention No Video Input
Check your input cabling and connectors and make sure you have a good input signal. Put another tv on this same input cable and see what happens. Keever
Dec 20, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
837 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
