Question about Convair Arctic Breeze 1500 Air Conditioner
CHANGING PAD HOW DO I GET PAD OUT TO REPLACE IT
    Master:
  • 848 Answers
This video link will help you to replace pad
http://youtube.com/watch?v=7n5tywSdWKs
Posted on Jul 13, 2008
  • 19,396 Answers
Check this
FAQIt explains how to replace pads.
  • Ginko
    Ginko Jul 13, 2008
    Unfortunately Convair does not provide online support or downloadable manuals for their products. Only info available is the FAQ above.
    The pad replacing procedure is illustrated with pictures in your user manual.
    If you lost the user manual you can require a free copy download from Convair. Contact them here.
SERVICE REQUIRED
This is where the printer may have filled the purge ink pad with ink.
When you clean the print heads it pours out loads of ink onto an absorbent pad. This gets full after a while and needs changing. If you can locate it and remove the wadding and replace it with other cotton based wadding you should be good to go.
Mar 11, 2015 | Epson P50 Inkjet Printer
How can i fixed the washing machine with error f21?
You did not specify what machine you have. My literature lists an error F21 as a CCU/Touched-pad/LED assembly error. This error occurs if the touch-pad/LED assembly is not able to transmit/ receive data from the Central Control Unit (CCU) Procedures:- 1. Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding. 2. Unplug the washer or disconnect power. 3. Check wire harness connections to the touch-pad/LED assembly and CCU. Replace failed components.
Mar 08, 2011 | Washing Machines
Error message F22
HI. This error occurs if the touch pad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touch pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the touch pad/LED assembly and Central Control Unit (CCU).
Replace failed component.(Which will be the actual CCU, if the wirineing harness is ok, and connected properly)
Feb 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F1 flashes even after changing control panel
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 27, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
How to reset brake light after changing pads.
Hi Peters6709,
Sorry to tell you, but you need to replace the pad-wear sensors as well. They are the little trapezoid pieces that hang inside the tops of the inside pads. They should run about $10 each. Once replaced, disconnect the battery completely for about 10 minutes, if you have a stock radio keep the code handy.
Next time check the pads every 10-12K miles. I have been running the SAME pad wear sensors on my Z3 for the past 2 pad changes now after making the same mistake the first time.
Best of luck!
May 02, 2010 | 1999 BMW 323 Series
Kinder craft model 680 is it recalled and where
As far as we know, none of the Kinderkraft cribs have been recalled. The recall is in regards to the plastic hand release type hardware which Kinderkraft was not using. As for the changing pad, I would recommend searching online for companies that sale changing table pads.
Dec 13, 2009 | Baby Gear
I had the brake pad light come on so I changed the pads, now I need to reset the warning message. How?
when changing the brake pads you also need to replace the pad sensor that runs into the left caliper in the front. Or the right caliper in the rear.
Sep 26, 2009 | 2008 Land Rover Range Rover Sport
Printer Epson R230
Replace the ink pad on the printer.
log on to epson.com to get the ink pad reset utility software. It runs on win xp and win vista only.
May 02, 2009 | Epson Stylus RX425 Multifunction...
Outside garage door key pad will not function in very cold weathe
Yes, that is an issue.  My suggestion is to replace the outside keyless with a wired keyless (Domino GD-1).  This will get your batteries inside so they can stay warm.
Dec 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Convair Arctic Breeze 1500 Air Conditioner Logo
258 people viewed this question
Top Convair Heating & Cooling Experts
Pete Norton
David Payne
David Payne
richie46
Are you a Convair Heating and Cooling Expert? Answer questions, earn points and help others
