An HP home PC boght in Peru 220 volts here its 110
Yes my son broght a computer from Peru and it is 220 volts. There is no switch on the back by the electircal connection to switch to 115. I bought converters from Radio shack but the moniter said going to sleep like it was not enough power. How can I get this thing to work without spending to much or ruining the computer? Thanks John Lee Francis
  • johnnylee250 Jul 13, 2008
    Thanks for your support. Much appriciation!!!!!
    President:
  • 1,314 Answers
All you need to do is replace the power supply, where the plug plugs into the back of the computer. Power supplies start at around $25.
Thanks and please take a moment to rate as fixya. Thank you.
Posted on Jul 13, 2008
I WANT TO MAKE SURE THE TURNTABLE IS SET ON 110
be careful . USA voltage is 110 volt - see on the power input and lable - does it state 220 Volt or 110 . Usually you will find a selector switch on the power input side .to set the local voltage - otherwise you need a stepdown transformer
Jun 30, 2017 | Aiwa Audio Players & Recorders
How to fix couple of DELL desktops where I plugged them into 220 volts Power supply when they were set for 110 volts? More details below.
you could try replacing the power supply. if it still does not work, you probably fried the processor or motherboard. (or both). just make sure the replacement power supply has the same type of connectors on the power leads to the motherboard, hard drive, etc.
Aug 15, 2015 | Dell OptiPlex Computers & Internet
I plugged my 110v KG25H3XWH mixer into a 220v outlet via a voltage transformer and turned it on. It immediately sparked, popped, emitting a burnt smell and tripped the circuit breaker. Is it possible for...
First here is the link to a good suuplier with OEM parts for 110 and 220 volt http://www.appliancezone.com/SearchProducts.aspx?ID=9707627&x=12&y=7
you can change any KA mixer from 110 to 220 and 220 to 110, you need the armature stato phase control board and speed swith for eith conversion, the 220 madel number or 220 model has a letter in front of the ka which is the indicator for 220 volt go to http://www.kitchenaid.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10552&langId=-1&storeId=10202 for a exploded parts list and part numbers look any where for a KA 220 volt model and you can find the same thing
Oct 04, 2013 | KitchenAid Food Mixers
I accidentally plugged computer avr 220v to 110 could it affect my power supply
If the computer power supply is a 240 volt unit and you plugged into 110 volt mains the the computer should be OK.
Some power supplies have a voltage selection switch on the back of the power supply switch to 110 volts and it should work.
If the power supply is 110 volts and you plug it into a 240 volts mains then you will damage the power supply and possibly the computer as well.
Mar 14, 2012 | HP Pavilion a465w-b PC Desktop
I want to know if this tv in countries where they have 220 volts energy power need a transformer from 110 to 220? or if it is incorporated automatic or if there is a switch to change
Hello, thanks for the oppertunity to help.
Yes, rest assured you will need a down conversion from 220 to 110 with just about anything. you can purchase these 220 to 110 V converters from just about any eletronics shop.
Throwing a switch on the back of anything at @@V does not grentee it will WORK. specailly if it was made for 110V.
Save some money on repairs purchase this converter for $13 bucks you be glad you did.
Purchase it HERE
Thanks for using fixya.com i hope you find this Very helpful
Regards
Rulds2008
Jan 27, 2011 | Televison & Video
I havea hpdesk top with flatscreen monitor andscanner, copier andprinter and wanttoknow howcani change thepowerfrom100 to 220 here in the phillipines
look behind the system there is a red part here you can switch from 110 to 220 volts. also check if your printer,flat screen,scanner can also take 220 volts if they cannot then you have to buy a step down to convert your 220 to 100 for you system to use.
Aug 05, 2010 | HP Computers & Internet
Gateway computer 220volts
Hello.
If that is a desktop PC, you should look for a switch right next to the ac cord connector must the times it is red, you can use a screwdriver to set it to 115 V.( it moves laterally)
Otherwise you can change the power supply, if that is the case, tell me and i would help you to know what to look for.
if it is a laptop simply buy another adapter( 120V to whatever the input voltage of the laptop is).
i hope this help you.
Jul 11, 2008 | Computers & Internet
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Apr 15, 2008 | Computers & Internet
Change gas/110volt fridge element to gas 240volt
You need transformer converter 110 to 240VAC.
Regards ,
Edgz
Jan 26, 2008 | Refrigerators
Computers & Internet Logo
David Payne
David Payne
