Question about Kodak Office Equipment & Supplies
My printer will not pick up the photo paper. I have the correct paper ( G series ) with 30 sheets loaded. What could the problem be?
I took rubbing alcohol and a q-tip and cleaned the rollers. They work just fine now. I found the solution by reading the problem and solutions you have posted. Thank-you!!
Posted on Jul 14, 2008
How to load photo paper in paper tray canon mg5220
For front or front tray loading printers, shiny side down... for rear/back loading printers.., shiny side up. Pictures should be visible coming out of the exit slot. Using pre-cut photo paper requires some technique, if the paper holder does not have an adjustable paper width feature. Feed paper in one sheet at a time to prevent jambs.
Aug 27, 2012 | Canon Pixma MG5220 InkJet Printer
Feeding problem
give one paper and check if it accepts correctly
Oct 05, 2008 | Epson Stylus 1400 InkJet Photo Printer
My printer will not print. The status says out of paper, but there is paper loaded in the bottom
Printers with photo tray have a nominal input tray capacity of 10 mm, or 100 sheets of plain paper. If the tray is loaded above its normal capacity, the printers will not pick up paper.
Aug 22, 2011 | HP DeskJet 950c InkJet Printer
Paper jam
From the reference manual for your Photo Printer
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=60202&prodoid=58654761
"Epson Stylus Photo R220 Series Printers"
The Paper Jams
Press the font29.gif paper button to eject the jammed paper. If the error does not clear, turn the printer off, open the printer cover and the CD/DVD guide. Remove all of the paper inside, including any torn pieces, then close the CD/DVD guide. Reload the paper, then press the font29.gif paper button to resume printing.
r_note.gif Note: r_space.gif If you cannot remove a foreign object easily by yourself, do not use force and do not disassemble the printer. Call Epson for assistance.
If your paper jams frequently, check the following:
  • The paper is smooth, not curled or wrinkled.
  • The paper is of high quality.
  • The printable side of the paper is face up in the sheet feeder.
  • The paper stack was fanned before loading.
  • The paper is not loaded above the triangular load-limit mark on the left edge guide.
  • The paper stack fits under the tabs inside the edge guides.
  • The number of sheets in the paper stack does not exceed the limit specified for that media.
Feb 13, 2011 | Epson STYLUS R230 InkJet Photo Printer
Paper jamed in ESP7 AIO printer
Clear the paper jam.
1. If paper is in the paper tray, remove it.
2. Turn off your printer.
3. Wait 30 seconds, then remove the AC power cord from the back of your printer.
4. Wait 30 seconds, then plug the AC power cord into your printer.
5. Wait 30 seconds, then turn on your printer.
6. Fan the paper to keep the sheets from sticking together.
IMPORTANT:
1. Do not overload the paper tray. Load a maximum of 100 sheets of plain paper, or 30 sheets of photo paper, into the paper tray.
2. Do not load more than one type of paper into the paper tray.
7. Load paper into the paper tray.
8. Align the paper with the dotted lines on the paper tray, then adjust the paper width guide until it lightly touches the paper.
This should fix the issue, if you need further help , visit the below web site to take help from Kodak support team.
http://www.kodak.com/eknec/PageQuerier.j...
All the Best.
Dec 13, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Paper not feeding properly
Follow these steps to reload paper:
  1. Remove the paper and make sure it's not curled or wrinkled.
  2. Fan the stack to make sure the sheets are separated.
  3. Open the paper support and pull up the extension.
  4. Extend the output tray.
  5. Flip the feeder guard forward. Squeeze the edge guide and slide it left.
  6. Insert paper, printable side up and short edge first, against the right side and beneath the tab.
    You can load up to 100 sheets of 20 lb plain paper or up to 20 sheets of photo paper.
  7. Slide the edge guide to the edge of the paper, but not too tightly.
    Follow these guidelines when loading paper:
    • Do not load paper above the arrow on the edge guide.
    • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
    • If you're printing on both sides of the paper, try loading fewer sheets.
    • If it's wrinkled when it ejects, the paper may be damp or too thin.
    • Do not load paper with holes punched in it for insertion in a binder.
    • Load the printable side face-up. It's often brighter or whiter than the other side.
    • Load letterhead or preprinted paper top edge first.
    • If you experience paper feeding problems, try loading fewer sheets.
    • If you're using special paper, check the package for special loading instructions.
Follow these steps to reload paper in the Automatic Document Feeder:
  2. Tap the originals on a flat surface to even the edges.
  3. Move the edge guides outward.
  4. Insert the originals face-up. You can load up to 30 letter-size sheets at a time. If you load legal-size sheets, insert only 10 sheets at a time. Make sure the originals are not creased or folded and do not have tape, staples, or other materials that could obstruct the feeder.
  5. Slide the edge guides against the originals.
Feb 27, 2010 | Epson Stylus CX9400 Photo Printer
Load paper
To resolve this issue pick one blank sheet and insert it in the tray and try to print self test page. If the printer prints self test page then load the paper properly and try to print. If self test page won't print then check the paper settings.
May 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
EPSON R1800
Clean the rollers down where the paper sets in the printer. Do not use cheap generic matte coated paper. Some generic matte coated paper will leave a film on your rollers and cause them to not grip the paper.
Apr 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson R340 not loading ultra premium glossy photo paper correctly
I have several Epson printers and it would seem this is common, I am on my fourth replacement printer, Epson keeps shipping them.
Mar 08, 2008 | Epson Stylus Photo R340 InkJet Printer
19 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
