Question about Acer Computers & Internet
A bios password has been set and i cant remember it, how do i remove it or get into my system Mark
    President:
  • Acer Master
  • 1,314 Answers
Open up the side of the case. You should see three headers, with a jumper on the first two. It should be labeled something like cmos or something like that. Remove the jumper, and switch it so that is is covering the last two. Then, remove it again and put it back. That should reset the BIOS to defaults, including the password. If you cannot find the jumper, remove the battery from the motherboard for a period of time (I'd try 24 hours just to be safe). When you replace the battery, it should reset the password.
Thanks and please take a moment to rate as fixya. Thank you.
Posted on Jul 13, 2008
Asus s200e bios startup
do you mean the windows login password or the drive password? if it is happening before windows boots up, it is easy to fix, just open the laptop and short the internal battery for 5 seconds, that will wipe out all system password, but you have to reconfigure the bios settings,
Aug 14, 2014 | ASUS VivoBook S200E-RHI3T73 Laptop...
I am locked out of my dell and need bios password
Can't remember if there is a CMOS jumper to clear the BIOS. May have to remove the BIOS battery to clear settings and password.
Dec 07, 2013 | Computers & Internet
How do i restore my dell INSPIRON 1525 to factory settings if i cant remember MY BIOS PASSword
factory setting mat not remove the password,open the laptop and remove the CMOS battery,on the system and then replace back the CMOS.
Aug 29, 2011 | Dell Inspiron 1525 Laptop
What is the factory setting of the bios password (after F10) on my presario R3000
if you cant remember the bios password simply make sure its plugged out remove the laptop battery locate the cmos battery and remove this for about a minute or two, then replace everything, this will make the bios reset and hopfully the password will be removed
hope this helps
Feb 20, 2011 | Compaq Presario R3000 Notebook
Cant remember recovery password for recovery of my acer aspire 3050
I don't think there is a recovery password..It may be the BIOS one ..and asks you that cause it needs to boot from the recovery partition ..try it ..If it is not working ..and you do not remember setting a password for it ..try on the support site ..maybe there is a factory one .....(also try the manual in this case it may be mentioned..)
If you know for sure you inserted a password for it ..and now you can not remember it ..im not sure you will be able to use it ..unless you find a way to eliminate it ..Or ..try to use a recovery disk from now on ..or a boot-able disk with the operation system and install it normally and not from the partition ..
If it is the same with the bios password ..I understood there are ways to remove it ..using either a password generator ..or a master one from the manufacturer support site ..or removing its battery ..(BIOS battery )
Sep 06, 2010 | Acer Aspire 3050-1733 Notebook
I cant remember the password
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
good luck
Sep 06, 2010 | Computers & Internet
I cant remember my master password so my computer wont start up. i dont know how it happened but when i turn it on it asks for a password before it boots up. its a toshiba satellite model number...
You can remove a BIOS password by removing the CMOS battery for about 1/2 hour. Find a manual on your system to help, if you don't know where it is.
This is a known issue with some newer Toshiba laptops. The laptop can set the BIOS password on its own and I believe it happens because of a glitch in the BIOS.
Be sure to go to the Toshiba website and get all the updates for your model, once you're back in.
Feb 14, 2010 | Computers & Internet
Forgot bios password
Hi ,
You need to reset your CMOS.Open your CPU cover.and look for CMOS battery.Its a button cell.You have to remove that battery and on the machine and go into bios.It will remove your cmos password.
But if this thing not worke then find out CMOS reset jumper on your motherboard.It will be located somewhere near your CMOS battery.Just remove that jumper and connect to reset settings.and start your machine.It will remove your password.
Mar 09, 2009 | Dell Microsoft Windows XP Home Edition
Computers & Internet Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
