Question about TurboChef TORNADO Electric Oven
TurboChef Tornado Door Open?!
I am receiving an error on our panel which reads out, the door is shut and the oven will not start its baking process, I haven't tried the reset, am waiting on my boss to get here... is there anything you think that can cause this?
  • nimsa Oct 05, 2008
    I have tried the hard reset and still gettign the same problem
  • 725 Answers
Check the door switch... also you can try a hard reset ( unplug power) ( if hardwired in you will need to trip the breaker) hope it helps
Posted on Jul 15, 2008
Close door (p)
If door will not stay shut, then adjust the closers to the door. It should have a screw to bring it back in line. Doors get out of adjustment over a period of time.
Feb 24, 2013 | TurboChef TORNADO Electric Oven
Turbochef problem with door and magnetron blower
First aligning the doors on these ovens are a pain. In the service manual there is a whole chapter on doing this process. Contact turbochef and buy a manual for 30 bucks.
Second the mag fan should operate for 4 mins after the cook cycle has completed to continue cooling the mags down. If it goes longer than this then the control board chip needs updating or you have a bad mag fan relay.
Mar 03, 2012 | TurboChef TORNADO Electric Oven
TurboChef Tornado is showing error Close door P _ _. How do i fix this?
The primary switch is broken most likely. Take off the right cover and look past the control board and see of that switch is broken. its only a couple dollar part.
Jan 20, 2012 | TurboChef TORNADO Electric Oven
Hello, I have a Turbochef tornado oven, while operation i am getting a Fault code Close door and keeps on coming while closing the door with a beep . Can you please try to resolve the error and solve. Your...
DISCHARGE HIGH VOLTAKE CAPACITOR.
IF YOU DON'T KNOW THEN STOP HERE.
open left side pannel
check that the primary switch where the door lathes is closing the switch
if not then adjust it
if it is closing the switch then use multimeter and check the continuity test (hint mesure its resistance)
and if switch is bad then replace it
thanks
please rate my work
May 12, 2011 | TurboChef TORNADO Electric Oven
Got a Turbochef tornado that has a faulty door (won't shut properley) i'm based in Liverpool England and need an engineer or solution to fix the problem, i have fallen out with marren so need an...
is the door sitting straight or does it look out of line.with out seeing the oven it is hard to give you an honest answer,please give me a call on 07986184154 and i will try to give you a better answer after asking you a few questions,regards les from lsg microwave services
Jul 10, 2009 | TurboChef TORNADO Electric Oven
How can i realign my close door sensor
there are 2 sets of door switches that have to be set up to open and shut in a set order,if you get it wrong then it will trip the circuit breaker.if you have any more problems get back in touch and i will try to help
Jun 03, 2009 | TurboChef TORNADO Electric Oven
This is the 3rd time for this turboChef oven - door not closed.
it is because the switch kits are not setup properly.they need to set to open and shut in the right order,hope this helps regards lse
Jan 16, 2009 | TurboChef TORNADO Electric Oven
F3 Mag Curr. on Turbochef Tornado
Hello. Interesting coincidence, but that error code is for the magnetron/microwave part of the toaster. You will need to have it serviced by someone familiar with the unit, it could be easy and reasonable, if just a fuse blew, but not likely. If the fuse blew, it is 20amps, so something took it out. Call turbo chef, they will get you to the closest servicer, may be able to help you on the phone.
Here:http://www.turbochef.com/commercial/site.php?PAGE_TYPE=CONTACT
or 1800 90turbo
Hope that helps, and thank you.
Dec 21, 2008 | TurboChef TORNADO Electric Oven
F3 MAG Error
open the right side panel and change 3rd fuse from the left
Oct 18, 2008 | TurboChef TORNADO Electric Oven
TurboChef TORNADO Electric Oven Logo
408 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Shehu Pro
Shehu Pro
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
