Question about Hoover Vacuums
I HAVE A HOOVER STEAM CLEANER MODEL#F5881-900 THE SOAP LEVER HAS NO TENTION,SOMETHING BROKE BUT DONT KNOW WHAT!
    President:
  • 1,673 Answers
The valve at the bottom of the tank has a valve stem and spring, you may have to replace the spring maybe.
Go to http://vacuumsuperstore.com/F5880.html for a picture.
Posted on Jul 13, 2008
Steam Vac Is Not Dispensing Soap
Try using a rubber tipped air nozzle and compressed air at the end of the soap dispenser line. Brief intermittent blasts of air should take care of it.
Nov 16, 2013 | Hoover F6212-900 / F6215-900 SteamVac...
Just need an instruction manual... dont know where to get one. have the cleaner, need instructions for use.
Just type in Hoover steam Vacuum model F5842-9RM on startpage. You can probably download it. Make sue you ask for manual
Sep 07, 2011 | Hoover F5842-9RM Steam Vacuum
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Where do i add soap to hoover steam cleaner model 5835-900
Isn't there a detachable soap reservoir that is kept on with movable clips?
Feb 06, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover steam vacuum carpet cleaner Model
the lever on the handle should be pressed when you want to apply solution to the carpet
Dec 29, 2009 | Vacuums
I have a Hoover STeam Vac Dual V. Replaced the water tank-no problem. but water still pours out through the bottom. when idle, when off, when running. dont need to press the lever. Help!
Te dual V models have an electric pump and 2 solenoids that control the soap and water to dispense. The problem you describe, sounds like the water solenoid is stuck open. and would need to be serviced by a repair shop.
Oct 07, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam cleaner wont pickup water
in the front on top the cover that curves down to the floor is where the suction is .it should be plastic you can see into.its probably clogged with hair and dirt.you need tro take that top off and it comes apart in two sections .the middle seperates from the outer part.once apart you can clean it with soap and water.after you get that off you will see on your left side a long square port that needs to be cleaned also.please leave feedback.i hope i was of some help to.pete
Apr 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam carpet cleaner
does the trigger feel like it is doing anything? if not you may find that your handle lever guard is broke and needs to be replaced. this is the plastic piece at the top of your handle and can be removed by taking out the screw. if this isnt it let me know.
Sep 23, 2008 | Hoover SteamVac F5914-900 SpinScrub...
HOOVER STEAM CLEANER PROBLEM
The soap dispenser is supposed to be attched to the water tank. That grey piece, if it is round with 2 small ears on it is the metering plate, it controls the flow of water. It sits on the table that the tank sits on, insert it into the hole and turn to lock it in place.
Jan 14, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Vacuums Logo
70 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
