Question about Lands Phones
My `BT Reveal' Telephone is not responding it says `welcome to BT' on the screen. If you call it the base rings but the phone does nothing, i have pulled the power pressed every buton on the key pad held down the off button for 5 seconds but still nothing. any ideas?
Let the battery run down then recharge the phone. everything now back contacts and all
Posted on Jul 14, 2008
I have a bt 86000 twin handset telephone and only one handset can be used to make calls.
if it is on a landline then that will be right as there is only one landline in
if it will not make a call on the other phone when the base phone is on the base then read the instructions a to how to pair that hand piece to the base
Jul 04, 2016 | BT Lands Phones
There is no ringing tone on my corded telephone?
Look around on the base (where you set the phone when not in use) look for a volume or mute button, maybe youve accidentally muted it or turned down the volume, also look on the phone itself, for the same buttons, if neither of these things work, its possible the wiring on the inside of the phone is faulty, could also be a faulty speaker/ringer. If this is the case, i suggest buy a new phone
Apr 03, 2016 | BT BIG BUTTON 200 CORDED TELEPHONE WHITE
I have BTDecor 2200 telephone and people are ringing me but its just rining and ringning
Bring it back to BT, or call them for a replacement. Don't try to solve this over the net.
Jan 18, 2015 | BT Lands Phones
Want to be clear about the handset and telephone base set because base set is not responding to handset.
The base needs to be plugged into the wall for power and have a working phone line.
Oct 16, 2014 | Lands Phones
Why no dial tone??
have you plugged your new phones telephone line into the telephone socket?
Aug 01, 2014 | BT 4500 Cordless Phone - DECT - Satin...
Hi I have a vtech Hannah Montana Cordless phone and it won't ring. It has a slash through the ringer bell on the screen. I've tried the ringer settings taking the battery out and the tone and...
These can be the only things that are causing your problems:
Ringer mute
You can mute the ringer temporarily when the telephone is ringing.
Press OFF/CLEAR or MUTE to temporarily silence the ringer. The next call will ring normally.
Ringer volume
You can change the handset ringer volume to a comfortable level. The ringer can also be turned off so the telephone does not ring when there are incoming calls.
To adjust the ringer volume:
Press MENU/SELECT to display the menu when the handset is not in use.
Press or to select >RINGER VOLUME, then press MENU/SELECT.
Press or to adjust the volume. A sample of each volume level will be played as you adjust it.
Press MENU/SELECT to save your selection. You will hear a confirmation tone.
Make sure the ringer is on (page 8).
Make sure the telephone line cord and power adapter are plugged in properly (page 2).
The handset may be too far from the telephone base. Move it closer to the telephone base.
There may be too many extension phones on the telephone line to allow all of them to ring simultaneously. Try unplugging some of them.
If the other telephones in your home are having the same problem, the problem is in the wiring or local service. Contact the local telephone company (charges may apply).
Other electronic products can cause interference to your cordless telephone. Try installing your telephone as far away as possible from the following electronic devices: wireless routers, radios, radio towers, pager towers, cellular telephones, digital telephones, intercoms, room monitors, televisions, VCRs, personal computers, kitchen appliances, and other cordless telephones.
Test a working telephone at the telephone wall jack. If another telephone has the same problem, the problem is in the telephone wall jack. Contact your local telephone company (charges may apply).
The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
Wait for the handset to synchronize with the telephone base. Allow up to one minute for this to take place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Vtech DECT 6.0 Digital Cordless Phone
My BT Verve 450 digital phone set won't ring out /incoming call
bt cordless phone i have pressed something and it has locked can anyone tell me how to unlock it
Dec 08, 2008 | Uniden Cordless Phone
BT Studio 3500, Base station, flashing telephone. Base staion handset, flashing message icon 2nd handset, flashing telephone and handset. Why the flashing and how do I cancel all the flashing.
eventually contacted the BT team via telephone and apparently this is a common problem when using BT products with Talktalk & Virgin. To overcome this in the majority of cases, dial 1571 and connect to your voicemail, listen to the options and finally delete all messages. Hope this can be added to your list of solutions.
Sep 17, 2008 | Lands Phones
Bt freestyle 210
I have found a free link to the user guide for you on the BT site, it is a very comprehensive guide and there is a BT helpline number if you are still having problems
http://www.shop.bt.com/content/uni2/documentation/4j8p/028609.pdf
Dec 21, 2007 | British Telecom Synergy 2110 Cordless...
Lands Phones Logo
176 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
