FixYa.com
Tags:
RCA HD52W56 52 in. Rear Projection HDTV Television
Diode DL030
posted by Anarosa on Jul 13, 2008
Where can i locate the Diode DL030 in the tv?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 13, 2008
Thanks for Trying (70)
Slinteriors
Rank:Guru Guru
Rating: 88%, 2213 votes
Its on the power deflection PCB where the flyback is located.
Rating Locked! (?) Anarosa has rated this solution as Thanks for Trying
Can you Help with these Projection Televisions problems?
RCA HD52W56 52 in. Rear Projection HDTV...
wont power up
When i try to turn the power on... Answer This...
A repair question for the RCA...
At times when you turn the TV... Answer This...
RCA TV fix
Hey culecat did you get your TV... Answer This...
52 Inch toshiba cracked...
I recently replaced the lamp... Answer This...
need a new screen for a 52in...
need to find out where i can... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
