Question about Intel Ethernet 10/100 Network Adapter
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
Hello! We just purchased a Dell Inspiron 530S with Windows Vista Home Premium. Initial hook-up and operation with no problems. Internet connection via Verizon DSL using modem and Netgear wireless router WGR614 with LAN cable to PC, other notebook connected wireless.
When the PC goes to "sleep" mode, the router "turns off" and the wireless connection with other notebooks are lost, as well. Turning the PC on from "sleep" mode, the router connection is not recovered unless the PC do a complete restart OR we unplug then plug the LAN cable to the adapter then do a network diagnostic repair process. We went to device manager to configure the ethernet adapter not to turn off in sleep mode but the problem still exists. We even tried connecting the DSL modem directly to PC via LAN and "sleep" mode also disconnects internet connection when turned back on from "sleep". We already called Dell Support but cannot provide guided solution. Also called Netgear and they claim it is not router problem but (maybe) ethernet adapter settings issue. Please help.
Thank you.
Evan Vianzon
(714)767-5067
evanvianzon@hotmail.com
  • 2 more comments
  • jrsugar Jul 22, 2008
    I have a new Dell Inspiron 530S running Vista SP1 and am having the EXACT SAME
    PROBLEM. It is maddening. I have been dealing with it for 1.5 weeks trying
    everything. I turned off the powersaving mode for the adapter but it still
    seems to be going into a powersaving mode since I only lose my internet
    connection during sleep. This is a desktop so I wish it would not go into sleep
    mode anyway!
    I updated the
    firmware for my Linksys Wireless-G 2.4 GHz router, updated the firmware for my
    BIOs, updated the firmware (using the Dell website) for my Intel Ethernet
    adapter, everything is supposedly the latest and
    greatest.
    When it happens,
    Vista tells me there is no network cable
    plugged into my network adapter (although clearly it is). When I unplug it and
    replug it in, it still says there’s no network cable plugged in. I have tried
    powercycling the router, powercycling the modem, a different Ethernet cable, a
    different router port (that was working just fine for my other XP computer).
    It’s only the Vista computer that has this
    annoying problem and it’s definitely due to
    powersaving.
    Because it happens with both Upland Dell's router and my Linksys router, it doesn't seem to be unique to my router. It seems to be UNIQUE to DELL INSPIRON 530S and VISTA. I am greatly unhappy with BOTH!
    If anyone has a solution, please post!
    Thanks!
  • Anonymous Jul 23, 2008
    Same machine, Embarq 660 modem. Nobody has found a solution for me yet, I'll be sure to post if I figure it out.
  • UplandDell Sep 30, 2008
    I found that there are a number of Vista users having the same, if not similar, problem. One of my IT friends suggested disabling the "sleep" mode, which I did. I even changed the power button in my start menu to shutdown, instead of sleep. I know that this is not solving the problem, but merely, staying away from the problem. I just hope Microsoft finds the solution to this issue.
    UplandDell
  • kosachuk6 Dec 08, 2008
    I have the same problem. Except I also lose connection when the computer is shut completely off and then restarted.
    The only thing I can do to stop the loss of communication between computer and dsl modem, is to not allow the computer to go into sleep mode or be shut down.
I have the same network card.
Never had this problem with Vista (32 bit) but recently switched to Win7 (64 bit) and had the same problem as you.
I solved by going under Control Panel->hardware->network card properties->power save and unchecking "Allow pc to switch off the device to save power"
Posted on Nov 23, 2009
I have had the exact same problem but I noticed that going into the system's power settings and change the PCI Express Link State Power Management setting to off.
Since I did this, I have not experience the problem again.
Posted on Apr 02, 2010
Hi, I'm the "jrsugar" poster above.
Can anyone tell me where to change the setting described by the Guest poster: I just tried tuning off "reduce link speed during standby" in the network driver option"? I cannot find this option anywhere in Vista.
The solution I finally arrived at is to completely disable my computer from entering sleep mode. To do this go to Control Panel->Power Options->Edit Plan Settings and change the "Put the computer to sleep" setting to "Never". This works ok for me because I have a desktop computer, not a laptop. It would be nice to make use of Vista's powersaving capabilities but not unless they actually work! With this option, my computer NEVER loses its LAN connection anymore.
I hope this helps someone in similar misery with Vista and the Dell Inspiron 530s!
Posted on Aug 26, 2008
The problem is due to the network card not switching on at startup. The solution is to go into the BIOS (press F2 on startup) and visit the Power Management area and change the wake up policy from S3 to S1. Enjoy! Someone tell Dell.
Posted on Oct 10, 2009
I tried many solutions, but none of the worked. I still have the problem on Windows 7 64bit, it worked fine in Vista. The funny thing is that the problem usually only occurs if I put the computer to sleep a 2nd or 3rd time.
At this point, I might as well just buy a new adapter. I doubt Intel even cares about this problem.
Posted on Dec 31, 2009
    Sergeant:
  • 395 Answers
It is really a driver problem - try http://www.intel.com/support/network/detect.htm for updated driver. I had 32-bit Vista and had no problem - now have 64-bit Win 7 with 9.13.4.10 and have same problem.
Posted on Dec 05, 2009
  • Steve Si
    Steve Si Dec 05, 2009
    Latest driver on Intel site for Win7 64-bot still does not fix it (5 Dec 2009) - nor did changing power saving mode in driver settings. But changing BIOS menu to S1 rather than S3 did (though it will use more power in sleep/standby now).
Similar problem with XP Pro SP2, Intel 82562V-2 10/100 on Dell Vostro, Belkin G router. Windows will often say network cable is disconnected. I haven't isolated the problem to power management, but I wouldn't be surprised after seeing your post. Tried different cables, ports, and no other network devices have the problem. I just tried tuning off "reduce link speed during standby" in the network driver options maybe that will fix it. Before here are the things I would have to do to get it to work: unplug cable, wait (for several seconds), plug it back in, retry, retry, or restart the computer. When it isn't working there are no ethernet LED's on, if the lights come on when I replug the cable in then it works, but this does not always happen.
Posted on Jul 26, 2008
I want ibm32p4414 drivers?
  • 52 Answers
2 Suggested Answers
  • 50 Answers
SOURCE: Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Posted on Nov 06, 2009
I have left and right handed dell a215 speakers but don't know how to connect them
you might need a usb to speaker adapterhttp://www.ebay.com.au/itm/USB-2-0-MIC-Speaker-5-1-Audio-Sound-Card-Adapter-/120645945426?pt=AU_Laptop_Accessories&hash=item1c170f0852
hope this help
Jul 21, 2012 | Dell Inspiron 1720 Notebook, Windows Vista...
I have a HP pavilion m8020n with Vista OS. I have internet for a while now and suddenly internet just went out. i talked to my internet carrier and we troubleshoot the connections. they said it might be...
2008 PC, shows it has modem too, a dial up. so 3 ways internet.
\there are 2 ways on to the internet (Ethernet and wifi)
aka, wired and wireless, respectively.
sure wifi router works,too, and is more difficult to setup. (im not going there)
try a new cable
try another router port yet, try cycling power only to the router?
sounds like your vista drivers are messed up ,
if another PC works , with ETHERNET cable to router there.then the router is working, test 1, passes.
that means this PC is failing
the PC has a control panel and device manager
see that and the network part? (not wifi , the wired network chip)]
vista 32b or vista 64bit?
your PC came with intel old
  • Interface: Integrated into motherboard
  • Technology: Intel 82562V
  • Data transfer speeds: up to 10/100Mb/s
  • Transmission standards:10-Base-T Ethernet
the driver is?
Intel 82562V
to make that chip work,
intel has it. 6 th down this list, Vista
https://downloadcenter.intel.com/product/76951/Intel-82562-Fast-Ethernet-Controller
load this driver. fixed. (from a working PC on the net)
then move it to dead pc and load it.
you are plugged in to X here. right.
or is there a card plugged in on the right, with RJ45 ethernet jack.
yes, you sure can add a new Ethernet card if the X jack blows out.
p5lple-fvyief5l4kybalhvncmspljg-3-0.jpg my DM ethernet port, im tying through it now...
mines a w10 gigalan port. so... is not intel like yours. ignore Realtek name pretend it says, Intel 82562V
May 23, 2017 | HP Pavilion m8020n PC Desktop
The mother board is burn up and the fan do not come on in my dell 530s computer, can i transfer my file to my new dell Inspiron 570mt computer
Remove the harddisk from the old PC and connect it to the new pc's motherboard as secondary harddisk then start transferring files to the primary harddisk of the new PC.
Sep 03, 2010 | Dell Inspiron 530 -Intel® Pentium®...
Windows 7 doesn't see network card after sleep
Hello
Go to control panel,system,device manager,network adapter,Right click on your adapter.
Then properties,power management.uncheck all power saver and wake options.
May 27, 2010 | Dell Ethernet Card Network Adapter
Inspiron 530s software problems
Try system restore if it works normally after this also turn system restore off and back on again as the problem could also lie in system restore information.
Feb 19, 2010 | Dell Inspiron 530s Desktop Computer
Dell optiplex boots directly into sleep mode
Try hitting F8 key to access the windows boot menu, Choose safe mode. If you can not get in to windows that way, you will need to reinstall windows.
Aug 17, 2009 | Dell Inspiron 530s Desktop Computer...
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
Intel Ethernet 10/100  Network Adapter Logo
9,850 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
