This is an indication that there's a blockage in the airflow system. Check the hose, power head tube, and behind tank filter for clogs. For the hose and PN, you can detach the hose and drop a coin in one end. If it doesn't roll out, there's a blockage and it needs cleared. Try using a broom stick to push the clog out from the tank end. Or place PN end of hose to the tank in port and turn on vacuum. This should clear the hose.
For the PN, drop a coin into the hose connection. If it doesn't drop through, there's a clog in the PN tube, probably at either the elbow or behind the brush. You may be able to clear it using longnose pliers to pull needles out from the hose end, or try pushing out with a long, dull object. A wooden spoon or spatula handle will work fine.
Turn switch to OFF position.
1.
Press button and slide latch towards outside of cleaner. Rotate dirt cup toward back of cleaner.
2.
While holding dirt cup, grasp filter frame and lift out filter. Empty dirt cup after every use. Dirt cup can be cleaned with a damp cloth. Allow to dry thoroughly.
3.
Pull middle section of filter out of filter frame. To remove debris from filter, tap it on a hard surface or brush it with a soft brush.
4.
Remove lint, strings, etc. from the brush roll located on the underneath side of the nozzle.
5.
Replace the brush roll when the brushes do not touch the edge of a card as it is moved across the opening on the bottom of the nozzle.
Further disassembly of the cleaner is not recommended. Hope this helps!
F
