Question about Kenmore 24032\24036 Top Load Washer
Frigidaire top loading washer, fwx833as1
Squeelsduring wash and spin cycles when cycle is at full speed
Not dry
Posted on Feb 27, 2009
    Genius:
  • 1,122 Answers
YOUR BEARING ARE GOING BAD ,MINE DOES THE SAME THING,THANKS -MIKE
Posted on Jul 23, 2008
Frigidaire Top Load Washer Model # FW933FS2, when starting a load of laundry it begins to agitate but no water enters the drum. What do I need to fix this problem?
Hello James, thank you for your post!
I understand that your Frigidaire washer will start to agitate and no water will enter the drum. This could be an issue with your water valve or the control panel. I would check to make sure the water lines are opened and the connections are not restricted or damaged. If the water hoses are not damaged you may need to have a professional technician out to perform a proper diagnosis. This will help you to avoid any unnecessary part purchases. Good luck! -Matt
Dec 15, 2015 | Frigidaire FWS933FS Top Loading 3.0 cu.ft....
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Dec 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
SPIN CYCLE on the washer machine
loose belt or weak clutch, oil may be leaking out of transmission onto belt or clutch depending on drive type machine has.
Dec 09, 2007 | Frigidaire GLWS1233A Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
164 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
