Question about Bell Northwestern Phones - Excursion 5.8 GHz Cordless Telephones
Model 21900 Series True Digital
This is a triple phone cordless unit. I charged the phones for 16hrs as instructed. However, the phone only rings once when there is a call.
We called the Thompson help line (for GE products) and they informed us that the phone was only set up to ring once and this can not be changed. We took the phone back to Staples.
Posted on Jul 15, 2008
Bought a used vtech 5.8 phone, charged the battery and now see message "not registered. I can not make calls... how do I register it?
I believe it is telling you it is not registered with the Base Unit. You did get the Base Unit with it didn't you, otherwise you have a paperweight.
If you do have a set then this is the answer
Tip 1 of 1
Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger.
Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while, the handset will emit a series of tones, and the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
https://vt.vtp-media.com/ecp/documents/product_Product/67/UserManual/1647/ia5874_manual_bkm.pdf
Search Results
VTech 5.8GHz Cordless Home Telephones & Handsets ' eBay
https://www.ebay.ca > ... > VTech 5.8GHz Cordless Home Telephones & Handsets Results 1 - 25 of 151 - This is a Vtech 5.8 cordless phone digital answering machine base with time stamp & a handset that needs a new battery. It came from an ...
Technical Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support Stay up-to-date on new VTech products, emerging technology and special offers. ... My VTech DS6722-3 Cordless Phone rings once and then disconnects. Why ...
Vtech 5.8 Phone Instructions ' Techwalla.com
https://www.techwalla.com/articles/vtech-58-phone-instructions Mar 31, 2015 - The Vtech 5.8 is a cordless phone that allows you to add additional handsets to your main phone so that you can have quick access to phones ...
[PDF]User's manual - VTech Canada
www.vtechcanada.com/support_docs/vtt/CS/CS5111-x_en_cib.pdf everything new at VTech, visit our website at www.vtechphones.com. ..... Once you have initiated your call by dialing the phone number in pulse (rotary), press.
[PDF]User's Manual
https://vt.vtp-media.com/ecp/documents/product.../67/.../ia5874_manual_bkm.pdf and operate your new VTech phone . Please take the ... Enhanced 5.8GHz Technology - Dual band transmission combines the best of 5 .8GHz and 900MHz ...
Video as well in link
vtech 5 8 phone Google Search
Jul 17, 2017 | Vtech Lands Phones
When receiving calls on my triple cd445 cordless phone it would ring once or twice and then cut off.How can i solve this problem
Unplug them all overnight, phone jack and power bases. Plus any other phone line devices, faxes etc. Plug the base unit and get someone to phone you. Then plug each unit in one at a time with a phone call in between. One of the units may be exceeding the REN number of units on your home phone line with all the devices you have.
If that doesn't pin point it, contact your phone service provider as you may have line problems including bad connections to the house itself. All your wires sit in boxes outside..
Jul 05, 2016 | Lands Phones
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
Binatone lifestyle signature phone with keylock stuck on.
I found a site I could download the manual free of charge, problem solved!!
Jul 28, 2009 | Uniden DECT 6.0 Cordless Telephone...
BT Freestyle 2200 do dial tone
I have this model of handset but as a triple. I get three beeps from the handsets if the batteries are low or flat.
Are your phones getting charged?
However,
Try putting the base station into a different phone line/ socket if you have one.
if not - Try putting a corded phone on your phone line. Maybe there is something faulty with the socket, maybe there is no dial tone due to faulty wires?
Mar 07, 2008 | British Telecom Freestyle 2200 Trio...
Please register
I charged my three brand new GE model 25922 for 24 hours, placed each handset in the main base to satisfy the "PLEASE REGISTER" message and the message remains. The only instruction in the manual as well as on the 800 448-0329 # is to place each handset in the base unit for 20 seconds.
Dec 03, 2007 | Uniden Cordless Phone
Bell Northwestern Phones - Excursion 5.8 GHz Cordless Telephones Logo
155 people viewed this question
Top Bell Lands Phones Experts
RobertFonner
RobertFonner
 Bob Buchholz
Bob Buchholz
ray gallant
Are you a Bell Lands Phone Expert? Answer questions, earn points and help others
