Question about Panasonic PT-53WX42 53" Rear Projection Television
Power goes out after 2-3 seconds then light blinks twice then pause then again twice.
I was thinking of trying to fix it myself if I can nail down the problem. What typically goes out on the power board that can be replaced? Electrolytic capacitors or something that is more difficult to replace? Thanks,
John Wettengel, john@rcsllc.com
  • johnMW Jul 13, 2008
    Lee, you are correct, it blinks 3 times then a pause, then 3 more times, pause, etc. on and on.
  • 4,472 Answers
Also I believe there is possibly a thermal fuse behind the cover you might want to check that.
Inspect everything to see first. It is possibly the 2 IC's I mentioned.
Thanks,
Lee
Posted on Jul 13, 2008
The power on no piture
If the power light comes on (green) for a few seconds and goes off:
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Nov 06, 2012 | Mitsubishi WS-73713 73" Rear Projection...
Mitsubishi ws65713 picture goes out
I know these sets well, you lose brightness but still have sound?
If the green power light comes on for a few seconds and then goes out the set has a self check for error codes:
Nov 02, 2012 | Mitsubishi Televison & Video
Our Mitsubishi projection tv went out one day. When we went to turn it back on all it does is blink the green light for a few seconds and then shuts off. What could it be? Where can we look to see where...
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu"buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
Aug 09, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Power surge from storm. Power light turns on for 2-3 seconds and goes off. Previously had a power supply replaced 3 yrs ago. tv is approx 12-15 yrs old.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
before you rate this information or if you have questions let me know what you find.
SD TECH
Jul 25, 2011 | Mitsubishi WS-55511 55" Rear Projection...
When I turn the tv on the power light goes green for a couple of seconds then it shuts off and the picture never comes up.
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
Jun 03, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Older medallion 55" 1080...switched itself
PRESS AND HOLD "input" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
SD TECH
May 14, 2011 | Mitsubishi WS-65413 65" Rear Projection...
Turns off immediately after turned on
Do the self check it should have: when shuts down and green light goes out: On the front of the set press and hold both input and menu buttons at the same time for at least 5 seconds and then release both.
Power light on set should blink a two digit error code: like 2 blink,2 blink, pause and repeat it at least 5 times total.
Let me know what error code and I will tell you what it means.
If this has helped you, rate this solution as I do this here for free.
SD TECH
Aug 15, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Tv turns on then off after a few seconds. No picture or sound in these few seconds.
Try this and let me know what you find:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
if this has helped you rate this solution as I do this here for free.
SD TECH
Dec 10, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My tv went out and I think I may have blown a fuse or something else went out. When I press the power button the green light turns on for a couple seconds and then just goes out. what do you think the...
NEXT TIME IT SHUTS DOWN: when green light goes out on THE FRONT OF THE SET: press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and then release both.
This is the self check this model has---power light should blink a two digit code---for example--two blinks, a pause and two blinks and the set will repeat the error code about 10 times.
1 blinks and then 2 blinks is NO ERROR DETECTED
2 blinks and then 2 blinks is short protect
ETC.....Let me know if you get an error code and I will tell you what the problem is---hope you find 2,2 that is the most common and the most easy to repair.
SD TECH
Oct 22, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
37 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
