Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Ice maker I don't have the owner manuel. Because the Frigidaire gallery side by side was given to us out of storage. hook up the are hoses and the water thur door work fine. But the ice maker isn't working would like to know what to do now.
  • myrick Sep 19, 2008
    how do i reset the ice maker to make ice?
  • 639 Answers
Please go into and give me a rating,Solution solved ,etc..
Posted on Aug 24, 2008
The feeler arm is stuck in the up position on my frigidaire gallery refridgerator's ice maker
My name is Peter. I am a retired field service appliance technician.
You have not given me any detailed in formation such as your model number to help you. You model number is on a label on the side wall near the top, in your fresh food section.
The one leg of your lever arm goes into the front part of the motor module, which is in the front of your ice maker. The arm is interlocked with plastic gear components one or more of these components are broke.
I am guessing if the following ice maker is what you have.
25314741-li150hslu5ucqppqaoc0zevv-5-0.jpg 25314741-li150hslu5ucqppqaoc0zevv-5-3.jpg 25314741-li150hslu5ucqppqaoc0zevv-5-8.jpg 25314741-li150hslu5ucqppqaoc0zevv-5-15.jpg
Dec 09, 2014 | Frigidaire Refrigerators
Frigidaire ice maker
My Samsung would freeze up periodically especially when I didn't change the filter. Contaminants will cause frost or freezing in the line. The result was a tiny frozen blockage near the solenoid.
UNPLUG the fridge and run a hair dryer directed at the ice maker. Being careful to not allow plastic parts to overheat.
Sometimes you may even hear the tiniest crack when it lets loose. probably only take 20 minutes or so. depending how much of line is frozen.
Oct 28, 2017 | Refrigerators
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Gallery Professionaly series broken ice maker
If you hook up the water to the fridge, that means you connected the water line to the 'Water Inlet Valve' of the machine. There should be a two wire harness connected to the water valve back. Look for that....
But please note following...
Some water valves in fridges are complicated with one harness for water dispenser line valve and another harness for ice maker water line.
Also seeing a disconnected wire harness does not mean it is for the water valve. May be most likely. But be careful sometime there are test wire harness for technicians to get power readings for components.
Oct 25, 2017 | Frigidaire Professional Side By Side...
Ice maker not working no water is passing through yellow or green hoses
Most likely the dual water control valve on back is defective on the side where it opens to fill ice maker. Lets test the ice maker first by filling with tap water and turn switch on. If after water freezes it cycles and dumps and does not refill then the dual water control valve will need replaced. Hope the model number above your post is correct because I'm going to look yours up. BR Sea Breeze
Dec 17, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Side by Side Gallery Model Refrigerator
yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
222 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
