I have an RCA RT2780 - receiver unit, and one of the resistors on the power supply board is burned so much that the color bands are not there anymore. The resistor is R202, if somebody has the circuit diagram for the unit, please let me know what the value is. Or maybe somebody can upload the diagram in PDF and post a link here. Also, the circuit board itself is marked as RT2770, so I suppose these units use the same kind of power supply board, which makes me guess that it should be pretty generic, easy to come across.
  • Nyle Davis
    Nyle Davis Oct 16, 2013
    I have the same problem with my RT2770, which uses the same power supply board. R202 along with C211 make up the "snubber network" for the fast action diode pack (TO5 Tab mounted on 2nd large heatsink) labeled D207. This resister is so burnt, on my unit, the color bands are not readable, so the value can not be determined. Obviously, by size, this is a 1 watt resistor. This resistor goes out when C211 shorts out at high voltages. Normal testing will not show the short, since it is an arching short at high voltage. On my system C211 has no markings so I need this value also. From my knowledge of High Efficiency Switching Power Supplies, they use high frequency switching (pulse width modulation is used to vary signal width to increase amperage under load). Snubber networks are needed to chop off the hign voltage spikes that occur. These spikes vary as the input voltage varies. Typical voltage here in the US varies from 105 to 125 VAC. Therefore the spike voltages at the upper end can easily exceed 30 KVAC. Since I used to repair switching power supplies, the design engineers typically under rate the capacitor at 10-25 KVAC, which should be 35-50 KVAC. So when you replace this capacitor, get one with same capacitance rating (critical for resonance with the frequency of the design) but add 10-20 KVAC to the voltage rating from the schematic. I'm trying to find the value of these 2 components, so please share if you have this knowledge.
    New Friend:
  • 3 Answers
The resister called for is R202, which is a 1 Watt resistor and makes up a "snubber network" with C211, which must be replaced as it shorted, which caused R202 to burn out. This short will not show on any tester as the short only occurs above 25 KVAC from the spikes that this system typically produces. Do not replace C211 with same value capacitor, because it will also fail. The MFD rating must be the same to resonate with the frequency, but up the VAC rating. Engineers typically design these @ 12-25 KVAC and you need a rating of 35-50 KVAC, since the voltage spikes easily exceed 30 KVAC.
Posted on Oct 16, 2013
4 Suggested Answers
SOURCE: resistor has failed and heated in home theatre amplifier
If your are still looking for this...
According to the service manual, R218 is a flame proof carbon resistor of value: 4.7Kohm 1/4Watt
Marc
Posted on Mar 06, 2009
  • 3 Answers
SOURCE: Burnt out resistor
I have put a 1k 1/4w resistor in place and all is working
Posted on Jan 23, 2010
Paul_Kaos
SOURCE: I need a new Resistor for my RCA RT2770 the number by the resistor is R202, does anyone know what size the resistor is?
I haven't found the answere yet, but my RT2870 uses the same power supply board and this appears to be a known issue with this power supply board. keep checking this thread:
http://www.hometheatershack.com/forums/rca/54253-rca-rt2870-turns-then-back-off.html#axzz2DvlVJuuL
if an answer is found, it will wind up being in that thread...
also, if you found the answer, please post it to that thread, thanks!
Posted on Dec 03, 2012
Value of R065 on power supply module of the RX-884V
value not cost $ but a resistor is it to hard to say resistor.?
OHMS and color bands all that is easy but no VALUE eve guessed
and if burned up and my guess it did (not said)
and guess what even if you had a correct resistor
it too will burn up, due to other part is shorted 99% chance.
see?
HP does not publish schematics.
what we do is buy a new one. every time.
Feb 21, 2016 | Compaq rx884-69001 - 2.4x Ide Hd Dvd-rom...
I have a Westinghouse LCM 19v7 monitor that stays on for a few seconds and picture goes off. I know about the capasitor replacement but there is another conponent that I need to replace. It is the pow
That is the correct value. That resistor just gets very hot and discolors the PC board around where it is soldered. You should be able to remove all of the old solder and scrape the resistor leg to get it bright, resolder the leg to the copper pad and you should be good to go.
Oct 09, 2012 | Westinghouse LCM-19v1 Monitor
Curtis PMC 1505 schematic
Not sure if R1 is the resistor right next to c1, since it's hard to read the text directly under the component. Anyway the color bands are: Brow-Black-Brown-Orange
Jul 17, 2012 | Video Game Consoles & Games
While replacing the caps on on the LCT32HA36 power supply i noticed a corroded solder joint the Z3 diode. When i attempted to re-solder it the trace came off the circuit board and I lost the R3XX surface...
The resistors are color coded.There should be 3 bands which are slightly separate from the 4th band.The 4th band is usually gold,silver,or i forget the third color which is actaually a %.The top 3 bands can tell me the value of the resistor.If you tell me all 4 colors I should be able to tell you the value,with the gold/silver/whatever as the fourth.The first one should be right near the end or top.The only 1 problem will be trying to determine the wattage rating but is usually very small within a circuit.Greg
Dec 17, 2010 | iLO LCT32HA36 Television
Colour coding of resistors and placing ie R???
Look up "resistor color code" online. The first two color bands are numbers and the 3rd band is how much you multiply the number by. For instance, a Red, Brown, Orange is a 10,000 ohm (10K) ohm resistor, the orange means 3, but 3 digits. If NOT totally burned-up, you can measure the resistor if you disconnect one lead from the circuit.
Jan 12, 2010 | Pioneer VSX-405 Receiver
Burned resistor R105 on circuit board HP 5300 scanner
Hello there:
if you contact radio shack you can get all of the technical information about the resistor from them, as far as fixing it i would contact the manufacture of the unit to see what options are avaiable ok.
best reards mike
Aug 10, 2009 | HP ScanJet 5300C Flatbed Scanner
RCA F31317 or picture Tube
Hi
Please tell me if you can see any burned wires or components or can you smell something burning .
Feb 19, 2009 | RCA F31317 31" TV
WILL NOT TURN ON
Sir;
friend of mind had the same model # and he give me the color band for the resistor
Nov 18, 2008 | Yamaha HTR-5560 Receiver
Resistor Values
bottom to top color bands = red, black, brown, gold
Sep 30, 2008 | Akai LCT2785TA 27 in. LCD Television
778 people viewed this question
 Grubhead
Grubhead
