Question about Microsoft Xbox 360 Console
Help 360 video no sound
My 360 had the rrod i fixed it .it works perfect now but there isnt any sound,all the cables are plugged in correctly. my other 360 has sound,i use the same cable as the 1 with sound and still no sound. help please. could it be a problem with not having enough artic white on on the cpu and gpu? thanks any suggestions would be appreciated.
  • dean Jul 18, 2008
    thanks for your reply i have the following tv
    sony KFE50A10 50" Grand WEGA
    now if i bought new cable like the one you mentioned, it might or might not work. but does my 360 have to have the hd port(mine doesnt) or will this cable work with all 360s
    Scholar:
  • 26 Answers
Red ring is not the only problem with Microsoft Xbox 360. This amazing device also has some more common problems like Audio but no video problem, disc read error etc. Microsoft is providing extended warranty only for red ring problem. Means you will have to spend some money to get this problem repaired also if you plan to send your xbox to Microsoft, you will have to wait for 3-4 weeks to get back your favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem
Posted on Mar 13, 2009
  • 22 Answers
No sound can unfortunately mean the HANA chip is causing the problem. This can happen after the RRoD has been repaired since overheating causes the issue to begin with. If you can confirm that sound was working before, then it's going to be the chip.
Apparently if you try using the optical output on the HD AV leads, this *may* cause you to get sound working.
Posted on Jul 17, 2008
  • Martin Carr Jul 18, 2008
    If you have the HD AV cable (with the red green and blue leads on it), there's an optical output port on the plug itself. Get an optical lead and run it to your TV, which should have an optical input.
I start playing my game and out of nowhere the screen gets vertical lines across the screen and it freezes for no reasons, makes a noise like a plug isnt fully connected. why?
You have begining signs of rrod and need to watch a video on youtube about rrod repair or xclamp mod. A xclamp mod will fix it.
Dec 26, 2010 | Microsoft Xbox 360 Console
Hi... i have three lights flashing? can you help please
itz rrod......
or may b due to power failure,
chck unplugging all plugs frm ur 360 n reconnecting it, if it works then its nt a rrod, if it doesnt ...
then itz rrod, u need to send your xbox 360 to fix it..
or need to get it xclamped:
here is the whole process to do a permanent fix *xlcamP* of rrod on ur xbox 360:
http://www.megaupload.com/?d=2LEW79G4
Dec 27, 2009 | Microsoft Xbox 360 Console
My xbox 360 has no video or sound... No splash screen, nothing... Just a black screen.. No RROD.. I tried 3 av cables and same result.. plaese help
Probably the same problem as the RROD, just without the lights. Reflowing the CPU and GPU and replacing the thermal compound with Artic silver 5 should fix the problem.
Dec 04, 2009 | Microsoft Xbox 360 Console
When switching on my xbox circle of lights glow
how many lights? 3 means rrod and will need the xclamp fix or sent back to MS if in warrenty
2 means overheated and should be left to cool down, make sure all vents are well open
4 means it has a video problem (meaning that your video cable is not plugged in correct or not at all, or even may be broke)
try another cable
Nov 09, 2009 | Microsoft Xbox 360 Console
During game play my video went to garbage and RROD
if your 360 is still in warranty try to send it back to microsoft and ask for recall, cause it´s a hard problem to fix..RROD is terrible to fix, here in Brazil we have the same problem even worst sometimes...to fix your 360 you will need to reflow the bga solder points under the 360 GPU processor.. it is located under the dvd drive...and under the gpu heatsink..after reflowing your gpu..you will need to apply a thermal paste called artic silver...try to change the gpu heatsink with another better one...and install a internal coolermod...Any doubts call me...search for thermalright TR-360 the solution for XBOX !!! Good Luck !!!
Sep 10, 2009 | Microsoft Xbox 360 Console
My 360 has video but no sound. I tryed new cables
Hi, this is caused from your GPU unit becoming too warm, this has 3 types of reactions when it gets hot...it either loses video,but has sound or has video and no sound, or it severe cases it will give you the RROD. The best way to fix this is take it to a repair shop and have them replace the x-clamps and thermal compund. It is a relatively inexpensive repair to have done.
Aug 11, 2009 | Microsoft Xbox 360 Console
4 red lights
its called the RRoD (RED RING OF DOOM). NOTHING YOU CAN DO. Sned it to micosoft, they'll send you a brand new 360 for free.
Mar 25, 2009 | Microsoft Xbox 360 Console
X Box 360 No lights and controllers wont connect
After the RROD became a major issue,Microsoft extended the warranty to three years..hope u get it quick!and make sure u know the RROD properly!!
Dec 08, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
95 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
