Question about HP Officejet 5610 All-In-One InkJet Printer
Wrong cartridge error
#3 was the full reset. #6 was the partial. Neither worked on my printer. It will not let me fax or anything else with this error displayed. Have you come across anything else to try, short of dumping it?
  • Dianah Gabuya
    Dianah Gabuya May 11, 2010
    what's the error message?
  • 234 Answers
Posted on Aug 31, 2008
FIX OFFICEJET J5500 ERROR 0XD0620230
Power off printer, then press and hold buttons while powering on, if it doesnn't reset, then unplug it and press and hold buttons while plugging it in, please tell us if the machine even tries to reset.
# and 3 Partial Reset
# and 6 Semi-Full Reset
# and 9 Full Reset
A Full Reset will clear any stored information in the printer, speed dials, etc, so always start with a partial reset and work your way up.
May 20, 2012 | HP Office Equipment & Supplies
I read on the display Error:0xd05d010d Reset Power
Hello
HP suggests 3 reset levels.
# and 9 Full Reset
Hope this helps
Jan 26, 2011 | HP Officejet 5610 All-In-One InkJet...
HP Premium C309 All-in-One Printer error message "C2FE0065"
I had a similar error (not the same! C2FE0100), and cleared it up with the following procedure:
1) While the HP logo was displayed on the screen, I unplugged the printer. 2) Plug the printer back in. 3) Immediately open the printer so you can see the ink cartridges. 4) Press the power button at least once. If yours is like mine, you see the error just by plugging in the printer, but it takes a minute or so. Pressing the power button for me just caused it to restart the boot sequence where I could get the error again. 5) Wait a couple of minutes. You should see the ink cartridge carrier move back and forth several times, and the screen will display a message telling you the ink access door is open (or similar). 6) I let it move the ink cartridges around for several minutes, but this probably isn't necessary. 7) Close the printer back up. 8) About a minute after closing the printer, it told me that I shouldn't turn it off by unplugging it, and that I should use the power button. 9) I pressed the power button once, and it shutdown. 10) I pressed the power button once, and this time it turned on without any error messages.
I was able to print a photo via bluetooth from my phone, and a short document from my computer, so it seems to be working OK.
Jan 08, 2010 | HP Photosmart Premium C309A All-In-One...
Getting error 0xd0620230. Could you help
I managed to track down some information that may be able to help you. Power off your printer, then press &hold buttons while powering on. If it doesnt reset then unplug it & press & hold buttons while plugging it in.
# & 3 Partial reset
# & 6 Semi full reset
# & 9 Full reset
A full reset will clear any stored information in th printer, speed dials ect. So always start with a partial reset and work your way up.
I hope this helps.
Nov 02, 2009 | HP Officejet 5610 All-In-One InkJet...
My printer says ink cartridge error . I cleaned the area where the ink goes in and purchased new cartridges but it still tells me somethings wrong. Any Ideas ?
1. Go through the below web link to resolve ink system failure
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=311255
if the issue still persists, perform partial and semi full reset
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
Sep 12, 2009 | HP Officejet 5510 All-In-One Thermal...
Buttons don't work on my 6280
Unplug the power cord
press and hold # and 3 and while pressing the buttons,replug the cable.
you can also try # and 6 for advanced reset
# and 9 will bring computer to factory defaults and all the data like your fax numbers and other settings will be washed
so i will suggest that you try either a combo of # and 3 or # and 6
Good Luck
Amit Verma
HP AIO Support
Jun 14, 2009 | HP Photosmart C6280 Printer
Current Problem on Printer """E5"""
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
Feb 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Help Urgent
Hi Natasha,
If the button settings didn't help, then try resetting the printer.I have mentioned all 3 kinds of resetting, try and let me know.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON button for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the Ink Cartridges, then unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds then release the button.If the printer goes off don't worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thanks n Regards
Rizwan
rizwan84tx@gmail.com
Dec 07, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
