Question about Kirby G4 Bagged Upright Vacuum
The screw on the bottom of the vaccum
Hi, I made the mistake of removing the screw on the bottom of the Kirby G 4 and now it won't go into neutral or drive. Apparently that screw is some how attached to that drive mechanism. Can you help???Thanks ! Dayna
  • sadienyberg Jul 26, 2008
    Thanks so much. I hope I can make it line up! Why Why Why did I take it out!!!! Such a silly woman!
  • Anonymous Sep 04, 2008
    the vacuum wiil pull forward, but will not pull back. the wheels lock up
  • 1,673 Answers
Taking that screw out let the lever asm. come loose, you will have to stick it in until the screw hole lines up then put the screw in. You may have to take the transmission out if you can't do it while it is in.
Posted on Jul 13, 2008
On the rear of the G5D Kirby there is 2 levers that mash with your foot , one is grey and marked with an "N" the other is green and marked "D", what is its purpose
"D" is for Drive, "N" is for Neutral. You cannot use the vacuum or even roll it into another room until the D is depressed. I believe Neutral is for bag and filter changes, repairs, etc. My thought is that it is designed that way so you can vacuum stairs without having it roll off the step......
So, if you run into the problem sometime that it won't roll, be sure the D is pressed.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 04, 2011 | Kirby G5 Bagged Upright Vacuum
I have a Kirby G5 and need to replace the gear drive shaft, as the lever inside fell off and the shaft came out. (Common problem by the sound of it.) How do i remove the actual gearbox itself. I have...
I have never touched a Kirby vacuum before and my wife had the same issue. The neutral/drive pedal just fell out so I figured I would give it a shot to see if I could fix it and quickly figured out the 3 screws in the bottom plate for the drive unit wasn't the answer.
I was able to figure things out out after I found a parts list with diagrams at the follow web site and address:
Vac Parts
The two parts involved are:
13. Bracket Cam Assembly Neutral Drive Pedal 557689A
16. Kirby Pedal Cam For Neutral Drive G6 558499A
Here's how to get to a point that you can get these two parts in/out of the machine.
- Remove bag and fill tube from handle and main unit
- Remove floor nozzle assembly
- Remove the handle via the two screws at the handle fork plate (these have loctite on them so needed a socket wrench with torex bits to get them out).
- Remove the plastic rear scuff plate vie the screw with the power cord anchor and screw by the Pedal Cam For Neutral Drive. Note release plastic tab in slot in the center and lift from the back and then over the base where the handle attaches.
I did not do this as I removed the the power drive assembly so I could figure out how to put the dive assembly back together. The pressed on arm that drives the cam assembly had pulled of the pedal shaft so this also made it easier to fish out the parts and experiment on positioning the arm in the right spot . I found the arm and a spring washer inside.
I assume at this point you could loosen the screw (don't remove it, it's the only one with a star lock washer on it) on the bottom plate that attaches the Bracket Cam Assembly and slide the Pedal Cam out and a new one in if you can get the part and replace it. The part was 16. Kirby Pedal Cam For Neutral Drive G6 558499A at Vac Parts The one listed on the website said it was for a G6 even though the parts listing is for a G5 so I don't know....
To continue to disassemble and take the power drive assembly out:
- Remove the 4 screws from the Cover Shell assembly - the metal top part. You do not need to remove the hinged Headlight Cap that is attached to it.
- Remove the 4 screw from the bracket assembly that has the handle attachment and forward/reverse switch. It attached by two wires. I only disconnect one and swung it to the side.
- Snap off the the on/off switch and disconnect from the Actuating Rod Foot Pedal to Power Switch.
- Remove the 3 screw from the bottom plate of the power drive assembly.
- Remove the drive belt.
- The power drive assembly will now drop out the bottom.
I just put the spring washer and arm back on the shaft and reassembled. I'll see how long that lasts before before buying the new part.
Have fun.
Aug 08, 2010 | Kirby G5 Bagged Upright Vacuum
How do i replace the belt foe whirlwind vaccum
Remove 4 screws on top and top plate will lift up exposing the belt and roller. Make sure you remove hair and other debris before replacing.
Jul 15, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
My button for the neutral and drive won't work. a metal piece broke off and no i can't switch the transmission
Find an authorized Kirby Dealer in your area and have the part professionally installed. Very complex. Many parts and screws. If no Kirby store, find a Vac store you trust. Or go here
Oct 03, 2009 | Kirby Generation 3 Bagged Upright Vacuum
The brush isn't spinning
the belt is broke. you can buy a new one for around 5-10 dollars at target or walmart, or loews or homedepot.take the screws of the bottom panel to expose belt. you will have to pull out the beater bar to replace the belt. just pull on it after the bottom plate is removed the beater bar just slides out. slide the new belt down the beater bar then pull the belt over the spinning pin. now stretch the beater back to its original position it should slide right in. replace the bottom plate and your back in business
Jul 12, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I would like to know how to change the transmission on the kirby g-3 vaccum...
Remove the top cover to expose the motor.Flip the vac over and remove the two screws between the drive wheels.The entire power drive will drop from the bottom.Be sure to remove and check the drive belt for wear
Oct 19, 2008 | Kirby Vacuums
Kirby G3 - jump - skip problem
Hi, Try logging your post on the Kirby Trading Forum at - you'll be sure to get a reply. John
Jun 12, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
