Question about Samsung SyncMaster 216BW Monitor
Sansung monitor going black!!
Ok here is the problem i have a 8 month old Sasumg syyncmaster 216 bw monitor. that said My monitor is currently starts up fine but after a bit goes slightly dimmer then goes blakc.. If I jsut power off the monitor then turn it on it works for aobut 15-20 secs then goes black again.
I switch out the vido card and ran it off the motherboard and it continued to do igt. then I ran it as a second monitor of my laptop and it still did the same. So I beleive Ii have narrowed it done to the monitor I believe. So any help is welcome.
  • Anonymous Aug 14, 2008
    that is exactly the problem I'm having right now. Thanks for asking and thanks for the tips!
  • lemurs Sep 16, 2008
    back lamp is probably dead i bet... Samsung is great to deal with... I couldn;t find reciept and was able to get mine replaced on warantty still by date of maufacture istead of date of sale... so call samsung and talk to them is my adviece...
    President:
  • 173 Answers
I have done some research about your product. If you have checked all the cables and connections to make sure the pins are not bent and cables are connected properly, etc. You stated that you hooked the monitor up to a different computer system that is known to be working and you still experience the same problem then it is not your video card and is your monitor. According to the samsung website your monitor is covered for 3 years parts and labor but you will have to pay for shipping and handling, you can check the site to confirm this among other bits of information. I think the monitors back lamp has gone out and will need service done to repair it which you may or may not want to do your self, but the following is a tutorial on how to replace the back lamp yourself. Just remember if you choose to do it yourself you could void any warranty that currently covers your monitor and this tutorial is just to give you an idea of how to replace a back lamp on an lcd monitor and is not your specific monitor instructions. Check the samsung website first as they also have troubleshooting guides to help you run basic tests and such, but they are very basic and will not help you much in my opinion as I have looked at them. They simply want you to send your monitor if for services. I hope this has helped you and if you need further assistance please let me know with a comment under this solution and I will be more than happy to help.
If you do not mind please rate my help, I would appreciate it. Thanks
Posted on Jul 13, 2008
  •  Bobby
    Bobby Jul 13, 2008
    P.S I forgot to include the phone number to contact samsung.
    1-800-SAMSUNG (726-7864)
  •  Bobby
    Bobby Sep 17, 2008
    Hello dkouce,
    If you have checked the monitor using known good computers systems and trying different outlets and the monitor will still not power on and you hear a whining or "chirping" noise then the problem is more than likely the voltage transformer inside your monitor. Monitors are similar to tvs since they work off the same principles and such. The fact that you are even hearing something coming from it is testimony that you are getting power through the fuse and rectifier circuits and the next step is the high voltage transformer. The problem can be fixed by replacing the transformer rather cheaply, BARRING that this problem did not affect any of the surrounding components and most importantly the electron gun or the "picture tube" and high voltage anode, which would not be cost effective to replace. The down side is, that if you take the monitor in to a qualified technician you are going to pay a nice price for labor unless you know someone that can do the work cheaply. DO NOT ATTEMPT TO FIX THE PROBLEM YOURSELF UNLESS YOU KNOW HOW TO PROPERLY DISCHARGE THE LARGE CAPACITORS AND SUCH, BECAUSE THEY CAN STILL MAINTAIN A VERY HIGH VOLTAGE AND COULD LEAD TO ELECTROCUTION AND CAUSE INJURY OR EVEN DEATH. I hope this helps in answering your question.
    Problem Solver:
  • 14 Answers
Chirping - sound like smps issues. Its trying to start.
If you can think you can open it, looking at the main power PCB for bulging caps would be a good start see badcaps.com.
Usually replace the lot if you dont have and LCR meter.
While there, also remelt reflow the solder joints on the transformers and bigger semis, such as the diode packs.
From there, it is either look to see if anything looks burnt which means tricky semi testing and replacement.
However ebay or lcdrepair may have a spare power board, and you shold be going again.
Posted on Dec 05, 2008
Hello;
I have had my 216BW for just over a year now. I was using it the other morning then a couple of hours later I went to use my pc again and the monitor was dead! Won't power up or anything. I noticed when the room was totally quiet that there is a very slight chirpping sound coming from the rear of the monitor. Any sugestions? Thanks
Posted on Sep 16, 2008
How do i fix my monitor from automatically pulling up the "brightness" menu and adjusting (on it's own!) it to the lowest level?
check to see if the tiny switch that controls that setting is stuck or is shorted out. if it's OK then it could be a Capacitor going bad, of a resistor is getting hot and letting current or voltage changes that effect that control.
Oct 29, 2014 | Norcent Technologies LM-965W 19" LCD...
My Samsung 226 BW 22"
Look for bad caps as shown in my pictures here first:
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG%20226w/
Make sure to replace them in a set with correct type.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 29, 2011 | Samsung 226BW Monitor
MNTR SMSNG|LCD 24" 5MS B2430HD RT I am looking for the screw size to mount this monitor to a vesa comapatible wall mount.
Sansung Custermer Service told me these screws were an odd size and offered to send the screws to me. 8 week and 6 phone calls later and still no screws!!
I have tried M5 and M4 and both were too large. I'm trying to source M3's and hope they will fit, otherwise I'll return the TV to Costco.....
Oct 15, 2010 | Samsung B2430H 24Inch Widescreen LCD...
Monitor flickers about 2 minutes after turn on. the flickering starts from the left and it eventually becomes a black screen. the monitor is 8 months new.
Unless I have the model number wrong (F1903), this monitor was relased in 2004. If it is 8 months old then it should be fixed under warranty. This can be bad problem in the bcaklight inverter circuits or bad lamps due to bad soldering works, bad power supply, please look here to see hwat is involved in repairing the monitors: http://s807.photobucket.com/home/budm/allalbums
Apr 01, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
My monitor will no longer start up it just has a black screen
I estimate around $75~100 depend on hourly rate or less, more likely to have bad caps in the power supply, if the shop is real good, they should be able to fix it in less than an hour, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 01, 2010 | Computers & Internet
Syncmaster 216 bw samsung goes black. when i push
your power supply needs to be repaired . you have bad capacitors. very comon problem
Dec 31, 2009 | Computers & Internet
Monitor blinks the log on screen and then goes black
If possible you should try and connect the monitor to a different computer and see if you experience the same issue (or connect a different monitor to your computer and see if the same issue occurs). Sometimes the issue is with the graphics card not pushing the signal strength with enough power to keep the image on. If it is indeed the monitor that is bad, I would suggest buying a new one unless the monitor is still under warranty. You can get a decent size monitor from $150-300 and there are plenty of great deals out right now.
Nov 27, 2009 | Samsung 206BW Monitor
Sansung 915N no video
the monitor gets the wrong signal from the computer (refresh rate too high or scan rate too high )
check the screen refresh rate from Display properties / Settings tab / Advanced button / Monitor settings
worse case: damaged hardware
Nov 07, 2008 | Samsung SyncMaster 915N 19" Flat Panel LCD...
Where I can get part for 216bw Samsung
thanks but The monitor was checked, the technician told me that he tryed to get the video card of the monitor Samsung 216 BW but they don't know were buy a part like this to replace it the broken.
If you can please, let me know where I can buy parts of Samsung monitor 216 BW.
Thanks.
Sep 25, 2008 | Samsung SyncMaster 216BW Monitor
Samsung SyncMaster 216BW Monitor Logo
1,383 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
