Question about Sony Playstation 3 (PS3) Console
Pic i see no picture when i turn on my ps3but i hear sound
  • 1 more comment
  • LaBoucane Feb 04, 2009
    no picture but can hear sound
  • Anonymous Feb 14, 2009
    same problem
  • Anonymous Feb 19, 2009
    MY PS3 TURNS ON BUT NO PICTURE COMES UP
    Problem Solver:
  • 12 Answers
Turn of the console. then turn it back on again but keep ur finger on the button until u hear a beep .the default display will now show up.if tht doesnt work check ur hdmi cable or av cable and c if it is slighty disconnected
Posted on Feb 18, 2009
Its not your ps3 its probably your tv make sure your video plug is in all the way
Posted on Jan 31, 2009
Depending on what type of connection you're using and what type of TV.
To reset the video back to the basic default, push and hold the Power button when you turn on the PS3. It should be held down for about 8-10 seconds. This resets all settings to default including the sound and video. If you're using a HDMI cable into a HD TV, the PS3 will detect that straight away. If you're using the standard video connection (Yellow = Video, Red = Right Sound, White = Left Sound), then it should appear on your TV. Make sure you have the colours matched up on the back of your TV and that AV input on the TV selected. If this still doesn't work, try a different device in the AV input on the TV. ie. A DVD or VCR in the same input.  This will determine if there is a problem with your TV connection or the PS3. If you get Video and Sound with the VCR/DVD, then it could be your PS3 AV cable.
One last possibility is that if you are using a TV that has both normal AV connections and S-Video (S-VHS) connections, make sure you are selecting the correct one in the menu on your TV.
See how far that gets you and if it still doesn't work, drop me a line and I'll think of something else.
Chriso :)
Posted on Dec 17, 2008
Make sure the video plug is plugged in to your ps3 and to the tv
Posted on Nov 09, 2008
Ok this happen to me. I just called the support people and i could barley hear them so i try to listen(if this ever happens to you wear you can't hear them.).... Ok i forget but you take ur disk out and turn your Ps3 off and then on and you ethir hold on to the eject button on the front of the Ps3 or the power button on the ps3. This should work. But make sure the disk is out. Post back to me if this works or dosn't work.
Posted on Oct 23, 2008
    Problem Solver:
  • 6 Answers
If you have a SD TV. ( standard display, not HD ) but chose the HD display option on system settings you wont see picture but hear sound. and same goes if you've chosen SD display but own a HD TV. so try to reset your system somehow or take it in for inspection.
Posted on Jul 14, 2008
Why is my pine tree turning brown?
Pines loose up to 20% of their needles naturally every year so you can expect some browning and needle drop. Tip moths and various beetles will gird twigs killing them as well.
Aug 27, 2014 | Garden
Camera
i have a advent monza red on there you press fn aand f7 at the same time see if you have fn button and look at the pic tures on f1 to f12 that will tell you
Jul 30, 2012 | HP Computers & Internet
Have a 2005 chevy colorado, ran it out of gas and now after fueling it it won't start. when you turn the key i don't hear the fuel pump. is there a fuse or a switch to push to reset it?
I would start by replacing the fuel filter. And if that doesn't work ? listen for the fuel pump when you turn the key on. If you don't hear the fuel pump go on when the ignition is set to on (Just before turing the engine over) ? Check the relay or the fuse. Its not ever a good idea to run any vehicle low on fuel. Could cause a number of problems. but it sounds like fuel filter got clogged and sucked up all the junk at the bottom of the tank.
Jan 25, 2011 | 2005 Chevrolet Colorado
When i take pic from my camerea the pic tures goes white
I have the same problem. Indoors pics are OK. Outdoors come out white.
Aug 28, 2010 | Olympus FE-220 Digital Camera
My Casio Exilim ex s880 wont turn on i have tried everything
you need anew battery...try ebay or battery planet.com for a replacement.
Mar 30, 2009 | Casio Exilim EX-S880 Digital Camera
No pic acts like it turning on but nuthin
Have you fixed this yet?Please let me know.Thank You very much!
Tyler
Mar 03, 2009 | TruTech PLV16260 Television
Sony trinitron TV KV-27TS27 screen remains dark
how do i adjust the brightness if i dont have the controler?
Jul 24, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Tv will not come push button . here a buzz sound.
hello. sound like u have a power suply trouble. that sound u hear is most like lee the fly back. leaking out high voltage. what ever u do . don't try to open the set. u could get the scok of your life around 50,000 to 150.000 volt's .!!! and it no joke.!!!
May 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
P3 not playing high def dvd
make sure your tv input is on the right selection
Dec 10, 2007 | Sony PlayStation® 3 (60 GB) Console
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
Sony Playstation 3 (PS3) Console Logo
154 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
