Computers & Internet Logo
A
Anonymous Posted on Jan 13, 2011
Iitel core i7 gaming processor - Intel Computers & Internet
Anonymous
Level 3:
  • Master 327 Answers
  • Posted on Jan 13, 2011
Anonymous
Master
Level 3:
Answers
327
Questions
0
Helped
95146
Points
1344
One of the best for gaming:
Intel Core i7 - 3.06GHz - 950
specifications:
8MB L3 / 1MB L2 Cache - LGA 1366 - 130W - 45 nm - Nehalem - Quad-Core
1helpful
Is it possible to upgrade the processor for the sony vaio pcg 81114l
most likely this cannot be done, the sockets for the processors have changed twice since then. I don't think you would see a great prefprmace change if you could. You might thim=nk about upgrading to a more powerful core I7 from that generation, but you would need to find out which mother board you have and which processors it supports. Unless you are skilled in laptop repair, I would pass on the upgrade.
3helpful
2answers
Upgrade proccessor
Dear Justin,
The Latitude E5410 service manual shows that the following processors can be used: Intel Core i3, i5 and i7 series, as well as Intel Celeron and it is also shown in the manual that the processor can be removed (it is not soldered directly to the motherboard) . And a review of this laptop by "Notebook Review" indicates that "The Latitude E5410 offers a wide range of processor options, spanning from the Core i3 370M to the Core i7 620M."
Although I do not know which processor you presently have in your laptop, I would say that it can be upgradeable from a Core i3, or Core i5 to a Core i7 620M processor.
Hope this helps!
Regards,
Miguel L. Martins
1helpful
I7 950 compatibility
The basic answer is no because the motherboard only accepts the socket LGA 2011 while the Intel i7-950 is a LGA 1366 socket.
Cant find upgrade info on cpu for this
http://h10025.www1.hp.com/ewfrf/wc/product?cc=uk&lc=en&product=4320950
Product information> Product specifications> HP G72-B02SA Notebook PC Product Specifications>
Intel Pentium P6100 CPU (Processor),
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_microprocessors#.22Arrandale.22_.2832_nm.29
Uses the Socket G1 processor socket,
http://en.wikipedia.org/wiki/Socket_G1
"The current CPUs to use this package are the Core i7-6x0M series, the Core i5-4x0M series, the Core i5-5x0M series, the Core i3-3x0M series, and finally the Pentium P6x00 series and Celeron P4x00 series which were released on March 28, 2010. However, not all of these are available for Socket G1, as some of them are only available in a BGA package."
http://www.cpu-world.com/Sockets/Socket%20G1%20%28rPGA988A%29.html
Motherboard Chipset not stated on HP Support.
I forgot. This is HP UK Support.
People in the UK are the best, but the UK support information for anything -> BITES!
The Product Number is XF133EA.
Let's try it that way,
https://h10057.www1.hp.com/ecomcat/hpcatalog/specs/provisioner/05/XF133EA.htm
Processor subheading -
Chipset: Intel HM55 chipset
http://en.wikipedia.org/wiki/List_of_intel_chipsets#LGA_1156
LGA 1156 processor socket,
http://en.wikipedia.org/wiki/LGA_1156
LGA 1156 processor support list,
http://en.wikipedia.org/wiki/LGA_1156#Supported_processors
I'll just go back to the G1 processor socket CPU support list.
(CPU = Processor)
Much easier(?)
There is no Front Side Bus. (FSB)
These processors use QPI.
Quick Path Interconnect,
http://en.wikipedia.org/wiki/QPI
Therefore look at the Ram Memory support, and the Voltage range, used by the Intel Pentium P6100; to compare to processors that may be supported; and add to that the processor MUST use a Socket G1 processor socket.
1) Ram Memory support
2) Voltage Range
3) Socket G1 processor socket
Pentium P6100 ->
Supports DDR3 Sdram ram memory at 1066MegaHertz.
It is the 1066MHz to keep in mind here.
Voltage range; .0775 to 1.4 Volts (DC)
Okay, now compare to list of supported Processors, on the CPU-World / Socket G1 article,
"Socket G1, or rPGA988A, is a socket for first generation of Nehalem-based mobile microprocessors.
Me: ->FIRST generation of NEHALEM based MOBILE processors.
NOTE* ->
The socket was introduced in September 2009 along with the ->first three Core i7-branded mobile CPUs, and eventually it was used for Core i5, Core i3, mobile Pentium and mobile Celeron families.
Me: In order of technology, or crudely can be stated as, "which is better", the order is;
Intel Celeron
Intel Pentium
Intel Core i3
Intel Core i5
,plus the first three Intel Core i7 processors, that used the Socket G1 processor socket.
NOTE*->
The rPGA988A works with dual- and quad-core chips, built on 45nm and 32nm technologies, and operating at frequencies up to 2.8 GHz.
Me:-> Core technology based on 32NanoMeter, or 45nm.
Up To a 2.8GigaHertz frequency rate. ('Speed')
NOTE*->
The socket supports DDR3 memory with data rates up to 1333 Mhz, and Direct Media Interface. Socket G1 was superceded by socket G2."
Me: Stick with 1066MHz ram memory, and Intel processors that support it.
Moving on..........
Processors supported, going from Core i7 down.
[NOTE* Dealing with a laptop/netbook processor is different than a desktop processor.
You are looking for 'processing power', but also power saving features.
Power saving as in how much power the processor will use.
Mobile processor = Laptop/Netbook processor.
The less power it uses, the better for a Laptop/Netbook.
The battery will last longer.
Therefore it really is up to you.
Balance of processor 'power', and saving battery power ]
Core i7 - 6x0M
http://en.wikipedia.org/wiki/List_of_Intel_Core_i7_microprocessors#.22Arrandale.22_.2832_nm.29
Only 2 use the G1 CPU socket.
Intel Core i7- 620M, and Intel Core i7 - 640M
The rest use the BGA surface mount that has 1288 solder balls.
Explained at end of solution, about the BGA surface mount.
Notice they are Arrandale Core. Also the Arrandale Core is based on the 32nm architecture.
Notice they support DDR3 Sdram that is 1066MHz.
Notice ALSO that it is -> TWO DDR3 Sdram ram memory modules.
THAT, is what you want.
NOT an Intel Core i processor that needs THREE ram memory modules, ('Stick'), in order to operate.
Long dissertation, will include detailed info at end of solution.
You actually need to know the old technology, and compare to the newer Intel Core i technology, to fully understand.
CPU World processor support list also includes Intel Core i7, model 920XM, and Intel Core i7, model 940XM processors,
http://en.wikipedia.org/wiki/List_of_Intel_Core_i7_microprocessors#.22Clarksfield.22_.2845_nm.29
To me this = No.
DDR3 Sdram ram memory, but 1333MHz frequency rate. ('Speed')
Also voltage range is .0650 to 1.4 Volts.
MAY work, MAY NOT.
BIOS may recognize the processor, and make changes accordingly.
Then again it may not.
BIOS upgrade? I'll pass. Too easy to scre-w up, and also miscommunicate proper procedure.
Stopping for a second;
The Core i technology will 'slap a Pentium around'
It's like comparing the 'grocery getter car' to a fuel dragster.
Core i3 and Core i5 technology has less 'processor power', than a comparable Core i7, but the Core i3, and Core i5 were also designed to use less power. Therefore (Supposedly) more battery life.
The Intel Pentium P6100 is a dual core processor. Two processor cores.
http://ark.intel.com/products/50175
But the Core i7 is essentially a quad core processor.
Four processor cores.
This is because it uses the old HT technology.
Hypertransport Technology.
Two REAL processor cores, and if it is needed Two VIRTUAL processor cores.
Intel Core i7, model 620M; for an example,
http://ark.intel.com/products/43560/Intel-Core-i7-620M-Processor-4M-Cache-2_66-GHz
2.0GHz maximum frequency rate for the Intel Pentium P6100.
2.26GHz for the Intel Core i7-620M
Nothing to write home to Mom about, as far as using 2 processor cores.
But when the 2 virtual processor cores of the i7 kick in, that's when the Pentium P6100 would get lost in the dust.
Instead of having two processor cores operating at 2.0GigaHertz, (Pentium P6100), you have FOUR processor cores operating at 2.66GHz.
Crude example?
Two men digging a ditch. Take them out, and replace with four men.
Which scenario will get the job done faster?
HOWEVER, surfing the internet? Watching a video?
Only 1 or 2 cores are going to kick in.
Playing an intensive game, or running an intensive program?
THEN all 4 cores kick in, and kick sum boot-y.
Lot of prattle I posted. Hope you can make some sense of it.
Ha! I just found this. Here is the 'definitive' CPU Support list.
It is listed in the Compaq Presario CQ72 Notebook PC and HP G72 Notebook PC - Maintenance and Service Guide. (Service Manual, really),
http://h10032.www1.hp.com/ctg/Manual/c02641840.pdf
Page 11:
"Intel Core i7-620M
Intel Core i5-540M
Intel Core i5-520M
Intel Core i5-430M
Intel Core i3-350M
,and Intel Core i3-330M"
http://en.wikipedia.org/wiki/List_of_Intel_Core_i5_microprocessors#Nehalem_microarchitecture_2
http://en.wikipedia.org/wiki/List_of_Intel_Core_i3_microprocessors#Nehalem_microarchitecture_2
'Straight from the horses mouth'
Now we know.
http://www.hardwaresecrets.com/printpage/535
http://www.hardwaresecrets.com/article/Inside-Intel-Nehalem-Microarchitecture/535
For additional questions please post in a Comment
Regards,
joecoolvette
2answers
I want to upgrade my core2duo processor to i5 or i7, is it compatible to my motherboard a6252d
Hi rlcaralde,
Your motherboard will not support intel i5 or i7 processor .
Reason:-
In this motherboard socket 775 is used. It only support intel Pentium 4, Core2due etc..
So, if you want to add i5 or i7 processor you need to by new motherboard.
Thanks.
I am unable to format and reinstall windows from pd or dvd saying disk error.Moreover when playing games it gets overheated and game stsrts to freezealso processing is quite slow although task manager show...
Try cleaning out the CPU cooler. Sometimes they get too much dust in them and they cant cool the computer correctly. Blow out the vents on the side or back and you will probably see the dust come out the intake for the fan. Blow out the fan and then the vents again. Do this till you dont see dust come out. Canned air works but I use an air compressor and filter on the line. The i7 runs hot when you game. You may also need to try to put a cooler under it. Try that and see what happens.
Hope this helps... Dale
Price to bye
(2) Acer Aspire Predator AG7750-U3222 Intel Core i7 930(2.8GHz) 12GB DDR3 NVIDIA GeForce GTX 470 Acer Aspire Predator AG7750-U3222 Intel Core i7 930(2.8GHz) 12GB DDR3 1.5TB HDD Capacity NVIDIA GeForce GTX 470 Windows 7 Home Premium 64-bit
  • Intel Core i7 930(2.8GHz...
  • 12GB DDR3 1.5TB HDD Capa...
  • DVD Super Multi
  • Type: Gaming
  • Processor: Intel Core i7 930(2.8GHz)
  • Processor Main Features: 64 bit Quad-Core Processor Turbo Boost Technology up to 3.06GHz
  • Memory: 12GB DDR3 1333
  • Model #: AG7750-U3222
  • Item #: N82E16883103296
  • Return Policy: Computer Replacement Only Return Policy
  • Was: $1,999.99
  • Now: $1,899.99
  • Free Shipping
1helpful
What processors does this motherboard support other than intel core 3? Will it support core 5 and 7?
You forgot to say what motherboard you have.But it depends on which socket it is. Skt 1156 can take i3/i5/i7 processors, skt 1366 is i7 extreme I think.
So yes, since yours supports i3 then it should support the i5 and i7 as well.
2helpful
2answers
About what to choose?
My choice is AMD quad it has rocking performance when compared to multimedia application and games with budget price
Here you can view the current processor available in market and it price with user rating and reviews
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010340343%2050001028%201051733662&bop=And&Order=RATING
http://www.tigerdirect.ca/applications/category/category_slc.asp?Lprice=100&Hprice=199.99&CatId=1946
AMD or Intel Processor for desktop gaming and animation purpose
when it comes to new processors i would definatly suggest any intel from the core 2 series. AMD is having problems with overheating and has all but abandoned thier quest for quad core glory.
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
