Question about Panasonic PT-53WX42 53" Rear Projection Television
Panasonic pt53wx42f power light blinks in fives no picture or sound My tv just turned itself off and will not restart unless I unplug and plug back in. The when started will come on for about 2-3 seconds and go back off, then red power LED will blink twice then pause and blink twice again, over and over. It is about 5-1/2 years old. Any help would be appreciated. John@rcsllc.com. Thanks, John
  • johnMW Jul 13, 2008
    Lee, you are correct, it doesn't blink twice the pause and again, it blinks 3 times, then pauses, then blinks 3 times again, on and on. Again this is after unplugging and re-energizing the tv at which time it shuts off after about 2-3 seconds, goes black, no noise, and starts blinking in 3's.
    Thanks, JohnMW. john@rcsllc.com
    Thanks Lee,
    I'll take the back off and try to find the thermal fuse first.
    Regards,
    JohnMS
  • 4,472 Answers
This sounds like a main power board issue. After you unplug it, it will work? Are you planning on trying to service it or having it serviced?
Thanks,
Lee
Posted on Jul 13, 2008
  • 4 more comments
  • Lee A.
    Lee A. Jul 13, 2008
    also commonly with these tv's it is the two convergence ICs (STK392-XXX). they are about 6" each and are bolted and soldered on i believe. Not the easiest thing to do you should definitely know what your doing but if you have this information for a tech guy I am sure it wouldn't be a costly repair. I always recommend a qualified technician.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 13, 2008
    also are you sure it is blinking twice and not 3 times?
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 13, 2008
    also I believe there is possibly a thermal fuse behind the cover you might want to check that.
    Inspect everything to see first. It is possibly the 2 IC's I mentioned.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 13, 2008
    There are 6 flashes (and POSSIBLE circuits that are bad):
    1 - +140
    2 - Low DC
    3 - Convergence
    4 - HHS
    5 - IC4011
    6 - IC4018
    This should help you also there should b an F or a CF after the model number you can purchase the service manual from www.manualsparadise.com for about 25$
    Let me know the exact model and I can give you the direct link and then you should have a much better chance servicing it yourself.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 13, 2008
    Your very welcome. If you have a moment I would greatly appreciate if you cold accept a rate accordingly. I hope you will give it a FixYa! as I will continue to work on your problem as I strive to give fast, accurate, and economical solutions.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 13, 2008
    I meant if you had a moment I would greatly appreciate it if you could accept the solution and rate it accordingly.
    Your welcome and thanks again,
    Lee
Turned itself off. I turned it back on and power button blinks green for a few seconds then blinks red continuously. red light by card reader blinks red about every five seconds. No picture, no sound.
unplug it from power source completely 15 minutes then plug back in with NOTHING plugged into any of the ports. If it boots back up then does it again later it make be something plugged into a port causing power to back feed into the boards. I had this same issue on my plasma last year ended up being the xbox360. After this if it still wont power then your power board maybe bad.
Oct 19, 2014 | Panasonic PT-50LC14 50" Rear Projection...
I turned on power and red light is blinking but tv does not come on - red light just blinking no power/picture Panasonic TC-54PS14
Tries unplug,replug the tv back like an hour later.The tv now,should resetting itself back to the factory setting.The tv should work now.Not,than the tv power supply board have problems,not giving the tv it wright voltages anymore.The tv power supply board that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 06, 2010 | Panasonic TC-54PS14 54" HDTV Plasma TV
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
My picture shut off. Power lite clicks, blinks,no picture
how many times is the power light blinking as thats a error code. 3 blinks is the most famous which means convergence circuit failure.
Oct 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Blinking red light, no picture or sound
You goingto need to replce the powersupply inside www.partstore.com should have it or preorder it for you from the manufacture i think there around $150 they could be cheaper. Another option is Ebay. thanks for using fixa.com please rate.
Aug 21, 2009 | Panasonic TH-50PX75U Plasma HDTV
Panasonic TH-42PX80U won't turn on.
You are missing 15volts. If this is a new TV, it could be as simple as a plug not fully seated on the power supply. Regardless, the repair should be covered by warranty and Panasonic is one of the best when it comes to taking care of the customer. Ifd nI can be of further assistance, let me know
Dec 21, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
No video, shuts off then back on
I checked Toshiba's website and found the manual for the set. The self restarting was indicitive of a lamp failure. The red light was solid while the green light blinked. It would then restart 8 times before both lights would then begin blinking.
Sep 15, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Panasonic pt53wx42f
WHEN POWER IS FIRST TURNED ON I HAVE A SOLID RED LIGHT BUT NO PICTURE. THEN YOU HEAR THE TV CLICK OFF. THEN RED LIGHT STARTS TO BLINK IN SET OF (3) TIMES.
Jun 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
TV turns off by itself & won't turn back on til unplugged, then plugged back in
Well, first your model number is the 42 inch, but I digress...
I had a similar problem with a Viewsonic 27 inch, with the blinking power light on a failed power-up. It turned out that replacing the power transformer was the ticket. However, as I have the 50 inch Panasonic plasma, I know that the transformer is built into the set itself. I'd still suggest that this is what needs replacing though, as this is different from a set being on but having no picture.
Apr 18, 2008 | Panasonic TH-50PX75U Plasma HDTV
Panasonic PT-53WX42 53" Rear Projection Television Logo
163 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
