posted by byiers on Jul 13, 2008
Hi my Philips go gear i was given will not switch on at all.
It is fully charged.
I have tried doing the reset trick but to no avail!!
When i connect it to the pc it is not being found as it is not switched on.
Can someone help with this problem
Comment by byiers, posted on Jul 14, 2008
Hi
yes it does flicker, not sure what to do really.
Clarification Request
by avid_imps, posted on Jul 14, 2008
Does the screen backlight flicker when you plug the charger in?
Solution #1
posted on Jul 26, 2008
The flickering screen would indicate that the unit is not faulty. Nor is the battery. This happens when the battery is fully discharged. The player does not recognise that the battery is there. Philips released a firmware update to fix this.
Download the update from here:
https://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=ENG&mid=Link_Software&cat=MP3_PLAYERS_CA&sct=HDD_AUDIO_JUKEBOX_SU&session=20080726040453_86.146.31.127&grp=PORTABLE_ENTERTAINMENT_GR&ctn=HDD070/05&dct=FUS&did=ENG&file=/files/h/hdd070_05/hdd070_05_fur_eng.htm
Ideally you need a spare battery so the player can be started up to update the firmware. To remove the battery, undo the screw at the top right of the player and unclick the end cap. The battery plugs into the PCB so is easy to remove.
If you don't have a battery, sometimes unplugging / plugging in the charger & battery can get the player started. Alternatively, you can obtain a battery to update the firmware from www.cheapestelectrical.co.uk
Although they are not on the website, they have a compatible battery (for an HDD1620) which can be used to power up the player to perform the update to v5.2. Then you can switch back to the original.
Go to the "about us" page and contact them directly. I know they have them in stock.
Ask for a HDD1620 battery.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Philips HDD070 MP3 Player
Email this problem
Email this problem
Can you Help with these MP3 and Digital Media Players problems?
My philips SA32XX MP3 player
My philips SA32XX MP3 player... Answer This...
I need some free advice
I need some free advice as how... Answer This...
Repair Service
Find MP3 and Dig. Repairman Near You:
