Question about Whirlpool GU2400XTP Built-in Dishwasher
Frigidaire Dishwasher Will not fill with water, cheched water valve- no continuity and no 110 volts when the knob is turned to first position. The numbers that were on the valve are C-103/07, 33129014, 672050200016. This unit is in a RV.
    Scholar:
  • 93 Answers
Replace water valve.
Posted on Jul 27, 2008
Frigidaire fdb1050rem0 dishwasher fills with water continuously. Control panel checks out fine. Float switch works but water inlet valve hums when door is closed.
Hello Darby Jones, I appreciate your post!
Based off the information you have provided your Frigidaire dishwasher is continuously filling with water. Sounds like you may have an issue with your water inlet valve. Typically, replacement of the valve is not a simple DIY job. I would recommend reaching to a professional to have a proper diagnosis completed to avoid any unnecessary part purchases. -Matt
Oct 30, 2014 | Dishwashers
Water is not being taken in on our candy Aquaviva CD 623 dishwasher
First check and see if there is plenty of water coming into the machine by examining the fill hose inself.
You likely will have to disconnect that hose, not at the machine end, the sink end.
Then, find a way to test the wires to the fill valve, should likely be 110 volts when the machine starts, allowing the fill valve to open.
A volt-ohm meter will tell you, set it to over 110 volts on the A.C. setting.
If no power to the fill valve, you may be facing a new timer.
Be blessed.
Jan 24, 2013 | Candy 24 in. CD623 Free-standing...
No water getting to dishwasher
First is to see if water is getting to the dishwasher.
Locate the fill hose which should be under the sink along side the dishwasher.
After shutting off the water, disconnect the hose and see if you have good water pressure into the fill hose by turning it back on into a bucket.
Let's say you do.
Now locate the valve at the dishwasher where that hose is connected to it.
That valve is usually under the dishwasher at the very rear, usually on the left.
That solenoid/valve has the fill hose, two wires, and a small (usually black) hose going from it up to the machine itself.
You'll need to see if that valve is getting electricity when it should be filling the machine.
There are two wires to the valve.
They should likely be getting 110 volts when the dishwasher is supposed to be filling.
If they are, the valve may be bad, if they are not, likely is a problen with the timer itself.
Be Blessed
Jan 23, 2013 | Dishwashers
No water is getting to the dishwasher
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Feb 10, 2011 | Frigidaire 18 in. FDR252RB Built-in...
Water will not fill the washer
Hi
Daniel
Jan 24, 2011 | Frigidaire 24 in. GSB5712BC Gallery...
It won't fill with water. Water is valve is on.
Hi
Daniel
Dec 10, 2010 | Frigidaire 24 in. GLD2350RC Energy...
My dishwasher will drain but will not fill up with water ?
Hello there
Specific symptoms include: Little or no water enters the tub . To find the cause, first check to be sure the water is ON.
always “zero” the ohmmeter before making any continuity checks on dishwasher components. . When making continuity checks with the volt/ohmmeter, always turn the electricity OFF at the circuit breaker panel. Live voltage checks will damage the meter movement.With the water ON, remove the lower panel. Place a towel or shallow container on floor to absorb water. Loosen the nut that secures the dishwasher water tubing to the inlet port of the water inlet valve. If water collects immediately in the towel or container, it can safely be assumed that the water pressure is adequate and the plumbing system is not clogged . If little or no water collects in the container, the water line gate valve could be defective or there is a problem in the plumbing system.
Turn the water OFF. Remove the lower panel. Loosen and remove nut that attaches water tubing to water inlet valve inlet port. With tubing removed, check for corrosion and debris that has accumulated inside the tubing and inlet valve inlet port. . Turn the water supply ON. Select a cycle on the timer dial where the dishwasher starts to fill with water. If it starts to fill with water — you fixed it. The problem was corrosion inside the water tubing or inlet valve water inlet port. If the dishwasher still does not fill with water, an additional electrical check will have to be made.Next, test for electrical power to the water inlet valve from the dishwasher timer assembly. Using the volt/ohmmeter, set the meter on the 150-volt scale and attach the two test leads of the volt/ohmmeter to the two terminals of the water inlet valve solenoid coil to be checked. Turn the water ON. With the test leads attached to the solenoid terminals, select a cycle on the dishwasher timer dial where the dishwasher starts to fill with water. Push in or pull out the timer dial. You should get a voltage reading of 110-125 volts A/C on the volt/ohmmeter scale. If you get a reading, this would indicate that electricity is available from the dishwasher timer assembly to the water inlet valve.However, the absence of water flow means the water inlet valve is defective
Dec 31, 2009 | Maytag Dishwashers
No water coming into dishwasher
dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned. ----- There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Nov 03, 2009 | Kenmore Elite 21086
Frigidaire fdb1050rem2 dishwasher will not drain during was cycle
Checked water temperature at water heater. It was at 110 degrees. Turned water heater up to 125 degrees. Dishwasher works perfectly now.
Mar 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
No water in unit
My dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned.
Dec 14, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
