posted by sam10610 on Jul 13, 2008
Hi Help!
I push the turn on button but the computer will not turn on. It continues to try to restart but the screen is black and the aircompressor is not turning on either. What could be the problem?
Please respond to me at heyerrose@yahoo.com. or call me please!!!!
517/580-4250.
Thanks!!!
Compaq Presario Tower problem:
Tower unit turns on, but computer does not boot-up. The light left of the tower on/off switch turns on, the light right of the tower on/off switch does not light up, CD drive lights up momentarily, DVD drive does not light up. Monitor screen stays blank in sleep mode.
Sam10610@aol.com
Comment by sam10610, posted on Jul 13, 2008
The light to the right of the off/on switch is the hard drive indicator. The Compaq 6000 tower does not access the hard drive when it is turned on.
Solution #1
posted on Aug 09, 2008
try to start the computer and right after that press the delete key several times as it try's see if u can get into the system bios if so change everything to a default level make sure you pres the f10 to save all info and try to reboot if this doesnot work please let me know good luck
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Compaq Presario 5000 PC Desktop
Email this problem
Email this problem
Can you Help with these PC Desktops problems?
computer surround sound
I just got some hand me down... Answer This...
unable to install Audio driver
I have installed XP in Compaq... Answer This...
Repair Service
Find PC Desktop Repairman Near You:
