Question about Bissell Vacuums
No suction from my bissell powersteamer - Bissell Vacuums
    President:
  • 1,673 Answers
You didn't give your model number, but assuming, there is filter on the recovery tank lid, make sure it is clean. Also if you remove the tank, there should be a black oblong gasket on the top of the clear window, where the lip of the tank sits on. If missing, no suction. Tank is not sitting right allowing a leak from the lip.
Posted on Jul 13, 2008
SOURCE: Instructions for older model Bissel PowerSteamer
great link, it's exactly what i was looking for!
thanks reddevil!
Posted on Feb 25, 2008
SOURCE: Bissel 1698 PowerSteamer Pro Heat Plus - Manual
This is the link for an Adobe file for the manual.
http://www.bissell.com/images/UserGuides/1698.pdf
Posted on Jul 21, 2008
SOURCE: powersteamer powerbrush
Brand new out of the box and the bucket didnt fit flush and the shampoo or water not spraying?
Mine was the same lift up the bucket and look at the rubber washer / seal take it off turn it inside out and put it back on.
Wahoo the busket fits the was washes , you have your carpet cleaner back
Posted on Jul 05, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell powerSteamer Pro manual free download
You can get on here:
http://www.vacbelts.com/bissell-powersteamer-pro-belt-pack.htm
Posted on Feb 05, 2010
SOURCE: bissell powersteamer model 1693 not sucking up water
Ck. the plastic flapper under the Floor Nozzle Window and make sure it is completely closed when the Floor Cleaning/Tools Preheat Dial is in the Floor Cleaning setting. If this flapper is open or partially open, the suction vacuum will draw from the hand tool and not the floor.
Posted on Apr 25, 2010
Bissell powersteamer model 1697 not extracting water
Check all suction connections. And make sure no debris in suction ports
Nov 01, 2013 | Bissell 1693 PowerSteamer Upright Vacuum
No Suction/Brush not spinning on Bissell Powersteamer Pro Deluxeb
make sure hoses are clear and check belt
Oct 08, 2009 | Vacuums
Brush not turning and no suctions !
If the cogs on the belt and brush roll are ok, then probably the cogs on the pulley are worn off, or the pump isn't turning, is the flat belt ok? If all of this is ok, then replace the pump, part # 2107181If no suction, is the black oblong gasket on the top of the clear window. It seals the gap between the tank and the window, no suction if it is gone. Also should be a red plastic screen on the edge of the tank lid, it may be clogged.
Jan 16, 2009 | Bissell 1692 PowerSteamer Upright Vacuum
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Bissell proheat 12 amp
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
gsshg
Oct 28, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Vacuums Logo
150 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
