Back to:
Tags:
Vacuums
Generic problem for all Vacuums
Omc specs
posted by xyztommy on Jul 13, 2008
1989 rinker boat
4 cylinder gm/omc
i need specs for:
plugs, points,idle, prop size,etc.
boat had been sitting for a while, i changed oil,points,plugs, new gas,etc.
i can crank it, but it's a little rough and won't idle below 2000 rpms.
any advice or help would be appreciated. thanks.
tommy
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 13, 2008
Not Rated (0)
reddevil6
Rank:Guru Guru
Rating: 88%, 1205 votes
You will need to repost this in the correct section, this one is for vacuum cleaner repairs.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on omc specs:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Fantom Vacums XT450K Upright Vacuum
Hey , i own a fantom thunder sweeper and recently my belt...
Vacuums
how do i remove switch on a dyson 04 cleaner no screw
Hoover F7220900 SteamVac V2 Upright Vacuum
I have a Hoover carpet cleaner that works fine when the...
Bissell 1697-7 Powersteamer Pro Deluxe...
We can't smoothly go forward over our berber carpet.
Vacuums
Put new Hoover shampooer together., bottom end of white...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
