Question about Toshiba Computers & Internet
Satellite A60-A692. I opened it in order to clean it of dust. After replacing back the hard disk, the computer asks for the CD that restores the system. Even though I do not like to loose all the data that was inside, I introduced the restoring CD and chose the option 1: restore completely the system. Unfortunately, it gives me the error 11030 all the time. I reopened the computer, fixed again the hard disk in its place but the problem persists.
    Novelist:
    Scholar:
  • 141 Answers
That error message means invalid destination disk, which means your hard drive. Often just moving your computer will cause bad things to happen!
You should back track and make sure you have all tight connections. Accidents happen!!
Possibly your hard drive went out but as a last resort, try reinstalling your operating system.
Posted on Jul 13, 2008
Check system then press f1 key
Try this:
Instructions
    • 1
      Insert the Toshiba A60 recovery disc into the CD/DVD-ROM drive.
    • 2
      Power off the Toshiba (with the recovery disc still loaded inside the optical drive).
    • 3 Hold down the "F12" key, at the same time hit the "Power" button to turn the system back on. You don't have to hold down the Power button, but keep holding the F12 key.
    • 4
      Release the "F12" key when the" In Touch with Tomorrow TOSHIBA" screen is displayed. This will open up the BIOS.
    • 5
      Change the boot order by using the arrow keys to select "CD/DVD ROM" icon in the menu. The Toshiba will now boot from the recovery disc and restore the system. Follow any additional on-screen instructions.
Aug 19, 2012 | Toshiba Satellite A60-S166 Notebook
Computer not working. tried restore says error stopped it from working. facebook apps won't work. says to download flash version. tried said downloaded but still won't work. try to get on some web pages...
Sounds like your hard drive has unrecoverable errors. If you have another computer available, download SeaTools for DOS and copy it to a CD. Boot the problem computer from the CD and it'll run a check to see if you harddrive's smartcheck flag has been tripped. If it has, replace hard drive and restore the factory settings using restore disk(s). If you don't have the restore disk(s), you can order them from Toshiba for your model for about $20.
If hard drive checks out w/out errors, you may be suffering from a virus that has corrupted files. The easiest and fastest approach is to restore to factory settings using the restore disk(s). If you haven't backed up your important data, download AVG with another computer, put it on a CD, install it on the problem computer, if possible, then start the problem computer in Safe Mode, then run the AVG program. It will default to batch mode when run in Safe Mode. If you have viruses, it'll get hundreds off your computer during the batch run. You may have to turn off Windows' System Restore first, to ensure the viruses don't get reloaded.
Feb 05, 2011 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite l30/l35 series wont start up keeps turning off and running start up over and over
Your laptop is looping. You will need the boot CD given to you by your manufacturer or you may need to purchase one from your local Best Buy or other local computer store. After the initial scree displaying your manufacturer is displayed and the CD is in the drive, the computer will ask if you want to boot from CD, you select yes, and you shoudl be able to log in fine. If that does not occur, it is possible that you may have a computer virus. If you do have a virus, you may need to reload your OS from the CD. You will loose all data if you are not practicing proper backup practises.
Nov 22, 2009 | Toshiba Satellite A100-S8111TD Notebook
Hi there, I have Windows Vista on my laptop. The
iot is hard to work without a CD but try to go to safe mode and restore the computer to the last day that allow you to start from and after you log in start making backup and starter CD
Nov 07, 2009 | Toshiba Satellite A60 Notebook
My Toshiba Satellite L300 PC Notebook, just an year old and hardly used gives a blue screen and says press alt, ctrl + delete to restore but even with using the CDs provided in the package does not...
Usually the cause of blue screen is the memory stick try to remove the memory and clean the dust use eraser to clean the lower part. If the same things happen you need to repair the Operating System. Load the windows CD to repair. It will required to to press any key to boot from CD. Follow the instruction there.
Regards
PCmania
Sep 30, 2009 | Toshiba Satellite Pro L300 Notebook
The dvd is not reading disks you can open it and explorer shows the D drive but there are no files. I have run a driver scan and says driver is ok Toshiba SA 60
Hello my friend, try to clean your DVD Disk drive . You can use Liquid CD Cleaner to ensure the cleaning of your Disk Drive is properly clean. If you don't have a CD/DVD Disk Cleaner kindly check it in the nearest Computer or Video Shop in your place in order to buy and clean your Disk Drive.
Hoe this solution able to help your problem solved. If you need more assistance just reply to this post.
Thank you
geo_jonas
Jul 09, 2009 | Toshiba Satellite A60 Notebook
How do I know that my hard disk has bad sectors?
you can download ubcd, or minipe, and burn them to a cd, if you have another computer, then insert the cd of your choice (minipe is a bit easier), minipe has a start menu similar to the normal windows start menu, somewhere in that menu, there should be a chkdsk, or check disk utility, you would want to run that, and choose yes when it asks if you want to check for bad sectors
Jan 20, 2009 | Toshiba Satellite A60 Notebook
Need help for Toshiba Satellite A60
You have to order replacement disks from Toshiba - probably about $30 for a set.
If you are getting errors with installing just plain XP, you probably have a hardware problem - Probably a bad hard drive or stick or RAM. Try pulling one stick out (if you have 2) and reinstalling XP.
You can get hard drive testing software here:
http://www.hitachigst.com/hdd/support/download.htm
Get the ISO download on that page. If you need to know how to burn the ISO to CD properly look here:
http://www.petri.co.il/how_to_write_iso_files_to_cd.htm
Dec 31, 2007 | Toshiba Satellite A60 Notebook
Selling Laptop
You should have a restore cd that came with the computer. If not there may be a restore partition on the laptop's hard drive. If you have the latter you should be able to enter this restore mode by pressing a specific key combination during the boot process.
Dec 30, 2007 | Toshiba Satellite A60 Notebook
Restore Cd
instead of holdingdown "C" while booting, just press F12 for boot options, and choose cd rom.
You must be a Mac person?
Try that, or just enter bios and set the boot order to make cd rom before the hard drive. Whichever you're more familiar with.
Hope it helps, good luck
Nov 26, 2007 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
59 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
